code po171 98 accord lx
I recommend that you take it to a shop with a scope and monitor the O2 sensor and have them do an Amp Ramp on the ignition coil. I have heard of the intake manifolds leaking air right through the pours of the aluminum. Check the MAP sensor voltage while on a drive, this may need a scanner but you can graph the volts with a volt meter yourself at different RPM ranges, long test leads. I think that Emission warrantee is up to 8 years???? and have the dealer check for TSBs and then do your own search to see if they are not coming through on free repairs................................ TSB 00-018, here did a search for you.
i figured out that the 2 o2 sensors were faulty one was working harder to pick up the slack.So the fuel reg was fucked too that was the code regulator and hose kit.
trocks
Jun 19, 2004 05:32 PM
