225/45/15 R3S04
Will 225/45/15 R3S04 on 15x7 Kosei K-1 with +38 offset work well? I'm not an ITR guy so I'm not 100% sure but I need to order some tires for a friend with an H2 ITR and I wanted to make sure before I ordered. Thanks.
i had 225/50-15s (toyo RA-1) on the same kosei's. all i encountered was rubbing. i have stock susp. so thats why. if i would roll the fenders, it would be no prob. but depending on the ride height and susp im not sure how they would do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6ghatch »</TD></TR><TR><TD CLASS="quote">Also will depend on suspension setup, ride height, spring rates, camber. More then likely the rear fender lip will need to be rolled.</TD></TR></TABLE>
Exactly. As mentioned above, Kumhos are no problem. Hoosier 225/45 S04/S03(s) are wider though and will rub a bit in the rear. No big deal though, as all you need to do is what Chris suggested above.
Jason-
who loves him some Hoosiers
Jason-
I ran 225/45 R3s03's on 15x7 +43 offset on stock suspension for 2 seasons.
They will fit, and they will rub both front and rear.
Front only at full lock and at the front of the rear LCA's, but neither is a huge deal. At most some melted fender liners and shiny rear LCA's.
moto27cm
20
Feb 1, 2006 06:12 AM
lundgren
Jul 7, 2001 08:31 PM
