Ignition fuse blowing
Hello, i'm having problems with my ignition fuse blowing about every 3 minutes or so when i'm driving. Checked for shorts/wires touching behind sterio area everything is fine was just wondering if you guys knew of any problem areas or some solution to this because it is very annoying. it's a 96 integra ls
Man that could be anyplace.... finding it is going to be the hardest part. Disconnect as much of the ignition circuit as you can so its not touching anything or plugged into anything. Then take a test light, leave the car off, and test it for ground. You shouldn't get any, but if you to, its means its touching metal someplace... if it DOESN'T get ground with everything disconnected, then its something else its plugged into.
