Hood is stuck after i changed out for a replacement one.
Old Aug 1, 2005 | 01:40 PM
ef9robert's Avatar
Default Hood is stuck after i changed out for a replacement one.
I have a 90 civic si, it had a dented hood and it took a few tries to get the hood to pop before replacing it with a used hood. After I installed the replacement. The hood would not close at all. It stayed in the "popped" mode. I had my brother pull the hood release and keep it pulled while i closed the hood. Hood closed flush but now when he pulls the release the damn hood does pop.
If anyone knows what I should do next to get this damn hood back up, please let me know.
Thanks.
Old Aug 1, 2005 | 02:03 PM
SiZ's Avatar
SiZ
Default Re: Hood is stuck after i changed out for a replacement one. (teamsonik)
Mine is permanently like that. You need two people. One on the front of the car, and one operating the latch.. Pull the latch until its tight in the car, and the guy on the front of the hood just give a quick "shove" down over top of the Honda symbol.
Old Aug 1, 2005 | 02:13 PM
APEX CRX's Avatar
you can try to adjust the striker latch, hood latch and the actually hood pin with the spring. it'll take a bit of adjusting but you can make it better. sometime you just need to adjust one and sometimes its a combination of all of them
Old Aug 1, 2005 | 03:11 PM
Jasond's Avatar
Default Re: Hood is stuck after i changed out for a replacement one. (APEX CRX)
My civic used to do this. The way I fixed it was to adjust the portion of the latch that is attached to the hood. If you look at it it has a slot for a flat head screw driver and is adjustable via a threaded portion on one end. Loosen the nut (12 mm maybe) give it a few turns out and it should fix your problem.
If that doesnt work it is possible you do not have the 2 parts of the latch aligned correctly. My hood latch had a bit of play in the bolt holes. I would guess and test and see if that will solve it.
Old Aug 1, 2005 | 09:05 PM
ef9robert's Avatar
Thanks, but how do i open it now. I tried having my brother pull the latch and bag on it. No luck. Please help me out.
THanks.
Old Aug 2, 2005 | 05:00 AM
Jasond's Avatar
Default Re: (teamsonik)
The way I always did it was to push and hold on the hood (think giving CPR) and have your helper pull on the hood release.
If that doesn't work you may have to take more drastic measures.
Old Aug 2, 2005 | 05:35 AM
Autoworks's Avatar
Default Re: (Jasond)
I had that prob too. I would just push down on the hood (like CPR as mentioned) Then yell CLEAR, then go pull the latch about 10 times till it would click. Repeat over and over till it works. Sometimes I would have to go out and give it a quick lift and then push.
Now that I think about it, I'm glad I got my cf hood, no latch just pins.
Old Aug 2, 2005 | 07:18 AM
ef9robert's Avatar
Okay, I will have try these additional suggestions. Do you think i can take the bumper off, bumper filler piece and remove the raditor upper bar to take the hood latch off?
Old Aug 2, 2005 | 07:57 PM
ef9robert's Avatar
do guys think this is the correct route to go?
89 pos
Nov 17, 2005 04:35 PM
kyle92integ
May 28, 2005 01:34 PM
93HatchCali
86
Nov 25, 2003 08:33 AM
