***PLEASE HELP ME OUT PLEASE*****
Old Aug 1, 2005 | 01:00 PM
purejdmsi's Avatar
Default ***PLEASE HELP ME OUT PLEASE*****
i have a 94 4 door gsr but i put in a 2000 si b16a2. do i need gsr axels or do i need 2000 si b16a2 axels please help thank alot
Old Aug 1, 2005 | 01:15 PM
Lan's Avatar
Lan
Default Re: ***PLEASE HELP ME OUT PLEASE***** (purejdmsi)
I would check the dealer. I don't know for sure but the splines on the shafts may be different, probably not though because they are both B series. So other problem may be width of them. Good luck and let us know!
Old Aug 2, 2005 | 05:43 AM
purejdmsi's Avatar
i dont think that the gsr one are long enough becaue it look like ther is a gap fron where the halfshaft and the axel meet or could my axel just be bad cause it makes a slight noise when i first take off some times like a klunk sound..... im open to ideas thank alot
Old Aug 2, 2005 | 06:12 AM
beaneg6's Avatar
either axles can be used but you need the complete set...gsr axles and half shaft or b16 axles with b16 half shaft! also why are you putting a b16 in a gsr integra?
Old Aug 2, 2005 | 05:28 PM
purejdmsi's Avatar
Default Re: ***PLEASE HELP ME OUT PLEASE***** (beaneg6)
WELL THE REASON THAT I PUT THE B16A2 IS THAT IT WAS FROM A 2000 SI WITH ONLY 31,000 AND MY 94 GSR HAD 130,000 AND THAN FOR SOME REASON IT SHOT A ROD THROUGHT THE BLOCK WELL AS FOR THE AXELS I HAVE 2 GSR AXELS BUT THE HALFSHAFT IS FROM THE SI
Old Aug 4, 2005 | 08:02 PM
purejdmsi's Avatar
does anybody else have any ideas.
brandynEG
Transmission & Drivetrain
Jul 28, 2017 08:42 PM
RHDintegXsi
Jul 20, 2006 12:33 PM
kino008
Nov 24, 2004 02:42 PM
mxer518
Jul 27, 2004 07:39 PM
