CTR head on B20 block, CR?
Old Aug 1, 2005 | 12:57 PM
xEnderx's Avatar
Default CTR head on B20 block, CR?
Just wonderign what kind of compression ratio (roughly) I'd be looking at with a straig swap from the CTR block to a B20 block. I know I'd need a main girdle and of course I'd be swapping the R oil and water pumps. Pistons stay in their respective blocks however. Because I don't feel like buying new pistons. Wondering if it would be worthwhile....I'm getting really fed up with my B16B's lack of low end grunt. Wish I had boght an ITR instead.
Old Aug 1, 2005 | 03:10 PM
xEnderx's Avatar
Default Re: CTR head on B20 block, CR? (xEnderx)
I know that some motor guru can answer this for me easily.
Old Aug 1, 2005 | 04:50 PM
00Red_SiR's Avatar
All Motor Mentor
If it's a B20Z block the compression would be roughly 10.03:1, if it was the B20B, it would only be about 9.15:1, stock head gasket, no milling or decking.
Old Aug 1, 2005 | 05:22 PM
xEnderx's Avatar
Default Re: CTR head on B20 block, CR? (00Red_SiR)
Thanks alot man. Hmm, I guess a B20Z with a thin HG would be a decnet setup then. Hopefully the lowered CR wouldn't make the CTR cams unhappy.
Old Aug 1, 2005 | 09:50 PM
noboostedEGo's Avatar
Could the bigger displacement help compensate for the lower compression?
...maybe??
Old Aug 18, 2005 | 05:57 PM
KingHornet's Avatar
Just finished, building my B20vtec. B20B block and type R head, compression ratio on the dial was 210 lbs/ft. Stock B20B pistons w/ new rings and head NOT milled. Duno how you convert that to ratio...
Old Aug 18, 2005 | 07:08 PM
RudeBwaiSi's Avatar
Why do you think you need a main girdle?
Old Aug 21, 2005 | 01:23 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: CTR head on B20 block, CR? (ChampWht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChampWht &raquo;</TD></TR><TR><TD CLASS="quote">Just finished, building my B20vtec. B20B block and type R head, compression ratio on the dial was 210 lbs/ft. Stock B20B pistons w/ new rings and head NOT milled. Duno how you convert that to ratio...</TD></TR></TABLE>
There is no conversion to figure out what the comp ratio is from a psi reading. You have to calculate it out using measurements and volumes. Try going to this site if you want to calculate it:
http://www.c-speedracing.com/h...c.php
Old Aug 21, 2005 | 01:55 PM
ThatsMyEG's Avatar
if you do a b20z block you need to get your pistons machined for vavle clearnce. ITS A MUST! or you could just retard your timing and not rev past 6 grand and youll be fine, actually just dont hit vtec and youll be ok..
Old Aug 21, 2005 | 01:56 PM
ThatsMyEG's Avatar
Default Re: CTR head on B20 block, CR? (ThatsMyEG)
you can also do this with a dremel.. theres a few people on HT that have done this and had good luck, i didnt!
manoloek9
13
Aug 8, 2010 06:36 PM
xEnderx
Jul 28, 2005 07:41 AM
louiejeff
Jul 5, 2005 02:59 PM
Boosteddc2gsr
Jul 14, 2003 07:06 AM
