leaking coolant even after headgasket
Old Aug 1, 2005 | 11:51 AM
Easyslider01's Avatar
Default leaking coolant even after headgasket
My coolant resevoir seems to always be empty every few weeks, theres no visable leaks and the oil is clean. I had the headgasket replaced when my head was pulled for cams so I know thats not the problem. Is it normal for it to go empty that frequent?
Old Aug 1, 2005 | 12:41 PM
Eva01's Avatar
Default Re: leaking coolant even after headgasket (Easyslider01)
Definately not normal to be empty every few weeks. Probably leaking from somewhere. Does your engine bay for have a sweet smell which is the tell tale sweet smell of leaking antifreeze. Probably a leaky hose or radiator.
If you have a leaky head gasket, sniff your exhaust gas for the same sweet smell of antifreeze. Another place to look is your oil, look out for a milky tinge which indicates a leaky head gasket.
Old Aug 1, 2005 | 12:58 PM
Default Re: leaking coolant even after headgasket (Eva01)
no engine bay dosent smell, oil looks clean and exhaust smells normal. I can't figure it out, the car runs fine and never overheats, i guess its fine
Old Aug 1, 2005 | 01:26 PM
Bbasso's Avatar
I have 60,ooo miles and i never added one drop ... opps I did change the thermostat once but reused the coolant
Old Aug 1, 2005 | 02:24 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Easyslider01 &raquo;</TD></TR><TR><TD CLASS="quote">My coolant resevoir seems to always be empty every few weeks, theres no visable leaks and the oil is clean. I had the headgasket replaced when my head was pulled for cams so I know thats not the problem. Is it normal for it to go empty that frequent?</TD></TR></TABLE>
Mine did this for a while, not sure I did a great job in bleeding the cooling system.
Good luck.
-Chris
Old Aug 1, 2005 | 03:03 PM
vtec.dc2's Avatar
there shouldn't be any loss.. do a cooling system pressure check according to service manual, that should narrow down to where its leaking
sailingstu05
Aug 20, 2008 11:08 PM
Racermech
Jan 19, 2007 07:30 AM
soon2bdropped
Sep 17, 2006 08:27 AM
EK k kay
16
Jan 1, 2005 12:27 AM
kysard
21
Aug 31, 2004 04:33 PM
