need some help from the turbo guru's
Alright, I decided I'm just going to turbo the d series cause I'm sick of being completely slow. Not going to do an engine swap cause I dont have almost 7k to do the k series swap. Here are some choices I have to choose from, but I cant decide which is the best. The first 4 are all used kits.
SF equal length manifold with external 38mm TiAl wastegate
T3 Super 60 trim turbo
Custom turbo intake
Custom dumptube to atmosphere
3 inch downpipe
3 inch exhaust w/ resonator
75mm HKS Carbon Titanium Muffler
Custom Intercooler piping (Powdercoated Candy Red)
Custom Intercooler (In one side and out the other)
High quality silicone hoses with T-bolt clamps
Greddy Emanage with all 3 harnesses and support tool
RSX Type S injectors
HKS SSQV BOV
Vacuum lines
Turbo Oil feed hardware
Price= $2800
The only con I see with this kit is I lose anti-lock brakes
Garrett T3 turbocharger
SF 4-1 tubular turbo manifold
SF 2.5" downpipe for maximum flow
SF PFM Fuel System
SF Intercooler: a 19"x7"x3" core with custom end tanks and transfer tube
SF Mandrel Intercooler Piping that is powdercoated red
TCC Works Type I Blow off valve
Steel Braided Oil feed lines and fittings
3/4" drain line and pan fitting SF's "no weld" pan fitting bolts directly to the pan
Synapse missing link
HKS digital boost controller
Autometer cobalt air/fuel guage and boost guage with pillar
Price=$2100
Garett T25 DUAL BALL BEARING TURBO WITH MANIFOLD AND DOWNPIPE, HKS BLOW-OFF VALVE, ALL HOSES AND CLAMPS, FULL PIPING, GREDDY INTERCOOLER, SIDE GAUGE POD WITH OIL TEMP, BOOST GAUGE, AND A/F GAUGE, APEXI TURBO TIMER AND GREDDY EMANAGE WITH ALL THE HARNESSES INCLUDED
Price=$2100
2 garrett T3 Turbo
*new (never used) oil feed line
*new (never used) oil drain line
3" downpipe
vortec fmu w/ fuel pump
Emanage w/ injector harness (bought from titleist71)
Turbo XS RFL BOV
Intercooler piping (black)
3" air intake to the turbo
3" Filter
Couplers & clamps
MAP sensor check valve
intercooler 12"
Polished Aluminum Alcohol injection canister
Alcohol injection nozzle
Pressure switch
synapses missing link
rsx-s injectors (bought from shadyimportracer)
Price=$2200
Order one from: http://truehonda.com/inventory.php?a...ctdetail&id=14
I was told I can change up the BOV to any1 I want, have the piping for it done in 3" for the same price as listed. They also might change up the intercooler cause I dont like the idea of having all the piping for it on one side.
Create my own(which will take me forver)
Any help on this decision will be greatly appreciated.
Custom turbo intake
3 inch downpipe
HKS SSQV BOV
Vacuum lines
Price= $2800
SF PFM Fuel System
Price=$2100
Price=$2100
2 garrett T3 Turbo
3" downpipe
Turbo XS RFL BOV
3" Filter
Couplers & clamps
intercooler 12"
Pressure switch
Price=$2200
the motor is like 3K and the swap is a couple of hundred. maybe like 6-7 hundred. it's better to swap because you start off with a better foundation and can make more power later. that's just my opinion though.
ForceFed Motorsports
Jul 21, 2009 07:34 AM
Huee
May 19, 2005 08:43 PM
null.
Aug 7, 2004 08:48 AM
EG*MonKEY
May 14, 2004 08:36 AM
B18 CYA
Apr 21, 2004 02:49 PM
