car running hot when a/c is on????
Well, I'm having an issue with my 94 del sol Si running REALLY hot when I'm driving with the air conditioner on......I do have a greddy kit installed w/ a front mount on it, I don't know if that affects is in anyway....I figured it was the thermostat so I replaced that, but it still does it. But when I take the air off the temp. goes back to normal. Anyone else have this issue?? Is just cause of the freakin hot *** florida summer that makes the car run hot, or could it be something else?? Hope that made sense to someone else lol
Turbo makes a car run add, and you add in Florida heat, and the heat of the AC... could be normal.
Try draining the old antifreeze, use a higher water %, and use redline water wetter.
yea, I wanna gonna pick up one of those triple core gangster radiators and some water wetter.....
anyone else ever have this issue??? Think the radiator could be clogged?
It might be your head gasket dude. I had the exact same problem. You better have that fixed before you blow your engine.
xwhitchx
15
Jan 14, 2012 08:45 PM
KyleVA
15
May 7, 2010 03:31 PM
