Header question: On B/D series hybrid, Is it engine dependent or Chasis dependent?
Old Aug 1, 2005 | 08:10 AM
PandaBear's Avatar
Default Header question: On B/D series hybrid, Is it engine dependent or Chasis dependent?
The reason I ask is for a potential D16 in LS and B18 in EG/EK, I haven't seen too many thread about asking which intake, manifold, header, cat, exhaust system type to use.
Any suggestion?
Old Aug 1, 2005 | 09:41 AM
nickG's Avatar
Default Re: Header question: On B/D series hybrid, Is it engine dependent or Chasis dependent? (PandaBear)
all depends on the motor...d/b series parts are not interchangable....
so b18 motor=b18 manifolds and ****....the d stuff will not fit..
your going to need custom exhaust w/ a swap anyway..the cat and exhaust are different lengths
Old Aug 2, 2005 | 08:45 AM
PandaBear's Avatar
Default Re: Header question: On B/D series hybrid, Is it engine dependent or Chasis dependent? (nickG)
So if that is the case there is really no point of putting D in B chasis, as the cost will make it uneconomical.
If that is the case I probably will just go B16 in LS then.
Old Aug 2, 2005 | 09:10 AM
allmotor dc4's Avatar
you should just keep the ls in the ls a b16 is torqueless and an integra is heavier than a civic
Old Aug 2, 2005 | 12:32 PM
nickG's Avatar
put the b16 in an eg and it will be pretty quick....
but yeah..no one goes backwards and puts a D where a B comes stock..
Bseries>Dseries
Old Aug 7, 2005 | 08:45 PM
PandaBear's Avatar
I like integra, but want something that can use less gas, so D15 integra.
eg_hatch_eg_hatch
15
Feb 17, 2009 05:37 PM
bibong
Dec 4, 2007 06:42 PM
93h22a1vtec
Jan 11, 2006 06:21 PM
B20B_Eg6
Sep 23, 2002 01:14 PM
