I have a short!
Old Aug 1, 2005 | 06:00 AM
PimpViking's Avatar
Default 1989 Si - Electrical problem
1989 Prelude Si
So here is the deal. My heater/ac fan and radio will not work when the car is turned on, but they are fine in accessory mode. I removed the steering column housing and found that there was indeed a burn wire coming off the ignition switch (white with black stripe). I replaced this wire and no dice. But when I turned the car off, this new wire burnt also.
So beyond the ignition switch I am lost searching for this short. Can someone please give me some help or insight into where I might find it?
Thanks!
Also, what is the IG-2 fuse for under the hood?
Old Aug 1, 2005 | 06:18 AM
The Weather Man's Avatar
Look for a pinched wire.....try looking up towards the headlights to make sure there isn't a pinched wire there - it happens a lot.....
Last Resort: You have to rig the power source of the radio.....not difficult.
Old Aug 1, 2005 | 06:21 AM
PimpViking's Avatar
Default Re: (NaptownKing)
I have thought about rigging the radio, but that does not fix the heat/ac fan. And it is gonna be a cold winter.
When you say look up towards the headlights, from the interior?
Old Aug 1, 2005 | 06:24 AM
Nah...actually under the hood near the headlights....a lot of times, people have pinched wires there....that usually cause shorts.....if that doesn't work, just start to randomly check voltages......its a tedious process, but its better than taking it to a dealership to do it....they'll charge out the ***....
B_Swapped93
Feb 28, 2014 11:37 AM
curtie94
Mar 15, 2011 09:35 PM
jordan_civic
Oct 15, 2007 03:03 PM
Full Intensity
Apr 27, 2006 09:08 AM
95cx
Sep 10, 2002 06:03 PM
