Problem w/ Field V-AFC on a d16y8 swap into a EF CRX.
I've got a d16y8 swap w/ pg7 integra ecu and Field V-AFC in my rex. I've noticed something strange in the last couple of days. I usually keep my VTEC point at about 5000rpm. I've noticed that under hard throttle, the Field will reset the VTEC point to whatever my current rpm is at the moment even after i'm cruising at 2200rpm. I end up having to re-set it the next time i'm stopped at idle(which sucks if i'm on the highway). I've heard of someone else having this problem with his b16 setup, but he just does the same as I do and re-sets it. The ecu isn't throwing any codes either. It's more of a nuisance than anything, but sucks if the VTEC is activated at low rpm's, ya know? Any input is appreciated.
Nevermind. I figured it out. It finally stopped raining, so I was able to take the CRX out. If I get on the throttle hard, then after backing off, I check the vtec point on the V-AFC while i'm still in gear, that's when the problem occurs. I know I've always heard to avoid setting the v-afc while in gear, but I didn't think that just checking the vtec point would be in the setting mode. If after I'm hard on the throttle and then check the vtec point AFTER I'm out of gear then it stays at my pre-set vtec point.
PaImportTuner
Nov 5, 2002 07:48 PM
NawTeeCRX
Feb 22, 2002 06:28 AM
