rear bumper and tail light removal?
I did a search and got no results for "tail light removal" and a few for bumper. I removed the 2 screws in the wheel wells and then two plastic screws underneath but the bumper didint seem to be loose. Should i pull harder or is there more screws. As for the tail lights, i removed the covers inside the hatch and took off the 4 8mm nuts but the lights werent loose. What am i missing?
thanks in advance.
thanks in advance.
To remove the tail lights you need to remove all the pop out plastic bits in the hatch that cover them up. When you get those out you need to unscrew the bolts that hold down all three pieces. Then unplug the wiring for your taillights. Then just tap the back of the taillights and pull at the same time and they should pop out. You might have to wiggle them back and forth to get them out all the way because the bolts attached to the lights get caught on the threads sometimes.
For the rear bumper make sure that you have the bolt above the exhaust removed aswell. Its hidden because the exhaust pipe is in the way but you need to remove that to get the bumper off.
CRX Forum
CRX Forum
FLIGL2003
Honda Civic (2006 - 2015)
Apr 11, 2007 03:43 AM
