Doing wire tuck, where to relocate map sensor?
Old Jul 31, 2005 | 10:27 PM
CRX MASE's Avatar
Default Doing wire tuck, where to relocate map sensor?
I'm doing a wire tuck on my 91 civic, and i have seen people relocate there map sensors under there dash but someone told me that map sensor vaccum lines need to be as sort as possibe, so where would a good place be to relocate the map sensor and have it hidden away?
Old Jul 31, 2005 | 10:54 PM
Bunger's Avatar
Default Re: Doing wire tuck, where to relocate map sensor? (DavilleKy)
Just swap to an obd1 style throttle body.
Old Aug 1, 2005 | 02:16 AM
CRX MASE's Avatar
Default Re: Doing wire tuck, where to relocate map sensor? (Bunger)
I thought about that, what would i need to run it? Wiring?
Old Aug 1, 2005 | 03:53 AM
Keith P's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavilleKy &raquo;</TD></TR><TR><TD CLASS="quote">I thought about that, what would i need to run it? Wiring?</TD></TR></TABLE>
The wiring should be the same. The sockets on the map sensors don't change.
You could also just zip tie or bolt the original map sensor under the manifold (as opposed to on the fire wall)
Old Aug 1, 2005 | 01:46 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Doing wire tuck, where to relocate map sensor? (Keith P)
i ziptied mine under the intake manifold.
97EKCRVtec
Aug 18, 2009 11:36 AM
Del Sol on Steroids
Nov 22, 2006 12:50 PM
Dr Pooface
Nov 19, 2005 12:37 PM
