no spark or fuel after wheel hop at the track. itr swapped crx.????
Old Jul 31, 2005 | 07:09 PM
jaydmcrx's Avatar
Default no spark or fuel after wheel hop at the track. itr swapped crx.????
I have a jdm itr motor, running ob2 stuff, and an obd1 ecu. Car was running great, and then i decided to go to martin. I got wheel hop like a ****, and then the car stalled. I have no fuel or spark now??? I checked all of the wiring, and it seems good. Tried new dizzy, still does the same thing. Tried a new main relay even, and still no luck. Anybody have any suggestions? I'm stumped as of right now. I didnt think wheel hop could mess up my ecu? But i guess i'll try another one tommorow i guess. I just want this damn thing to run.
Old Jul 31, 2005 | 07:16 PM
JDMCivicEF9's Avatar
Default Re: no spark or fuel after wheel hop at the track. itr swapped crx.???? (jaydmcrx)
Check your wiring connections, grounds, ECU, and main relay.
Old Jul 31, 2005 | 07:38 PM
jaydmcrx's Avatar
Default Re: no spark or fuel after wheel hop at the track. itr swapped crx.???? (JDMCivicEF9)
checked all of those, minus the ecu wich i am checking tommorow thanks any more suggestions? This happen to anyone else before?
Old Jul 31, 2005 | 08:00 PM
Andy R's Avatar
Are you sure there is both no spart and fuel? Or just no start? When you turn the car to ign 2, does the fuel pump prime? If the pump isn't running and the main relay is good, then I would have to say its the ecu or its connection at the ecu.
Old Jul 31, 2005 | 08:42 PM
jaydmcrx's Avatar
Default Re: no spark or fuel after wheel hop at the track. itr swapped crx.???? (Andy R)
fuel pressure gauge at ignition two reads 0 fuel pressure. And took the spark plug out, and turned the car over many times, and zero spark from the spark plug. I hope its the ecu, cuz im all out of ideas.
Old Jul 31, 2005 | 08:48 PM
Dancing is Forbidden's Avatar
Is your fuel pump priming? Check CEL's. Is it solid?
Old Jul 31, 2005 | 09:10 PM
jaydmcrx's Avatar
cel is solid, will not show me any codes.
Old Jul 31, 2005 | 11:39 PM
ecovillain's Avatar
Default Re: (jaydmcrx)
doesnt a solid CEL mean your ecu is fuxored?
Old Jul 31, 2005 | 11:41 PM
DohcVtecCrx's Avatar
Default Re: (ecovillain)
yes solid ecu is code 0 bad ecu...is it chipped or stock?
Old Aug 1, 2005 | 12:22 AM
91civicEX's Avatar
Default Re: (DohcVtecCrx)
if u have a solid CEL that doesnt turn off and ur ecu doesnt throw codes it could be a fuse. check ALL ur fuses. mine blew one under the dash and i had the same symptoms
Old Aug 1, 2005 | 12:25 AM
Default Re: (91civicEX)
interesting what fuse was it the alt fuse?
You could be on to something, no spark, no fuel ect.
Does the cel just stay on or does it go off for a fraction of a second before it comes back on?
Old Aug 1, 2005 | 09:16 AM
jaydmcrx's Avatar
My ecu is chipped. It's a hondata ecu, but i am running a kenji chip for now, until i was going to get it tuned. The light just stays solid.....I hate these damn cars sometimes, good thing i have a daily driver. lol.
Old Aug 1, 2005 | 12:48 PM
slammedef8's Avatar
that weird
slammedef8's Avatar
???? hmmmmmmm
Old Aug 2, 2005 | 09:26 AM
jaydmcrx's Avatar
Default Re: no spark or fuel after wheel hop at the track. itr swapped crx.???? (slammedef8)
Old Aug 3, 2005 | 07:27 PM
jaydmcrx's Avatar
Ok well i tried a different ecu, and still the same out come. I ground my diagnostics wire, and no cel, and the engine light just stays solid. I have now come to the conclusion, (hopefully) that the ecu is not getting power, like a ground wire, or power wire has come loose. Has this happened to anyone before?
Old Aug 3, 2005 | 08:21 PM
90sohcHATCH's Avatar
maybe a FUSE???? try looking at aLLL fuse;s
Old Aug 3, 2005 | 08:35 PM
Skinflute22's Avatar
check the engine bay fuses there is one that is for the ecu if that blew... then yes you woudldan't get power
Old Aug 3, 2005 | 09:39 PM
jaydmcrx's Avatar
Default Re: (Skinflute22)
checked all the fuses a gazillion times. that was the first thing i checked, along with the main relay. Thanks for the concern tho guys. i appreciate it. really i do. Now onto following wires, until i find something.
Old Aug 3, 2005 | 09:47 PM
do you have the ecu pinouts?
the ecu power is on plug "A" on the left side...
Old Aug 3, 2005 | 10:12 PM
crxgator's Avatar
this happened to me and my zc...i was ******* stumped and couldnt figure it out for the life of me...i then sold the car after i parted it out...
g/l
Old Aug 3, 2005 | 10:22 PM
jaydmcrx's Avatar
Default Re: (crxgator)
yikes thats not what i wanted to read.
Old Aug 3, 2005 | 11:40 PM
91civicEX's Avatar
try another ecu. they do go bad sometimes.
Old Aug 4, 2005 | 09:23 AM
jaydmcrx's Avatar
already tried one.
Old Aug 4, 2005 | 09:25 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicEX &raquo;</TD></TR><TR><TD CLASS="quote">try another ecu. they do go bad sometimes. </TD></TR></TABLE>
its not the ecu, i tried 3 on mine, all same result...it probably a loose ground somewhere...when it comes to wiring, that is the aspect i hate about cars...
