Help, Fixing CD Player holder in 3rd gen Teg!
Old Jul 31, 2005 | 06:54 PM
j87w's Avatar
Default Help, Fixing CD Player holder in 3rd gen Teg!
I have a 95 Teg. The whole "console" where the cd player is and the little tray under it comes out. It was in there fine for over a year. Out of know where it just flys out the other day when I was making a pass down the 1320. Now it just comes out all the time. What could be the problem?
Old Jul 31, 2005 | 07:22 PM
b18cDA's Avatar
Default Re: Help, Fixing CD Player holder in 3rd gen Teg! (j87w)
it might have broke...try taking it out and then secure it in anyway you can ... ducktape
Old Aug 1, 2005 | 10:59 AM
j87w's Avatar
Default Re: Help, Fixing CD Player holder in 3rd gen Teg! (chris91DA)
Thanks for the reply, but can someone give me a helpful reply to my problem?
Old Aug 1, 2005 | 11:09 AM
mrdeadman's Avatar
They let me pick
just the little tray under the cd player comes out? or the cd player itself or the little place with the ash tray and lighter? or what?
Old Aug 1, 2005 | 11:16 AM
j87w's Avatar
Default Re: Help, Fixing CD Player holder in 3rd gen Teg! (mrdeadman)
Yes, just the CD player and the gray tray under the CD player come out. Not the ash tray or the lighter.
Old Aug 1, 2005 | 11:25 AM
mrdeadman's Avatar
They let me pick
ok you have to take out the part around your shifter, i dont know what its called and also the cigarette lighter and ash tray to do this. but there are two pain in the *** bolts that hold your cd player in and sometimes they come loose if not screwed on properly. they are underneath the cd player holding it in from the bottom so the head of the screw is facing down. one on each side of the cd player. there is a little bracket thing made of sheet metal that these screw into and also the player sits on youll see when you look up under there. if the little box under the player comes off separately, there are two bracket things that hold that to the cd player, on on each side of the player that bolt to the box. you need to put the cd player back in before you put this box back on, i think, otherwise you may not be able to get to those two PITA bolts. if you have anymore questions, just post or something again, i may have left some things out, sorry. hope that helps.
Old Aug 1, 2005 | 11:36 AM
mrdeadman's Avatar
They let me pick
one more thing, those two bolts should already be screwed into the cd player, they are silver, i think they are 8's i had to use a 1/4 socket drive with a deep well to get them. you do not have to remove them from the cd player, they will slide in to the mounting place with the cd player, you will see. those little brackets that hold the box on should also already be attached to the player.
Old Aug 1, 2005 | 11:50 AM
j87w's Avatar
Its not just the CD player by its self coming out. Its both the "console" and the CD player coming out together.
Old Aug 1, 2005 | 11:57 AM
mrdeadman's Avatar
They let me pick
define "console" please
Old Aug 1, 2005 | 12:25 PM
j87w's Avatar
Its that small tray or box right under the cd player on 3rd Gen tegs. That and the CD Player come out as a whole.
Old Aug 1, 2005 | 12:56 PM
dokesdc2's Avatar
mrdeadman is right. the little tray under the cd player is actually attached to the cd player itself with a couple mounting brackets. secure the cd player and the tray will go with it.
Old Aug 1, 2005 | 12:58 PM
mrdeadman's Avatar
They let me pick
i just explained to you how to fix that problem. the reason it comes out as a whole is because there are only 2 bolts holding the entire set up in. the ones that mount the cd h.u. to it's sheet metal bracket. how is that coming along? im seriously not lying to you or anything. ive done this before on my teg.
dokesdc2's Avatar
Default Re: Help, Fixing CD Player holder in 3rd gen Teg! (dokesdc2)
to clarify, the tray is mounted to the cd player and nothing else. turns out to be a bit of a pain if you want to put in a new stereo and keep the tray, because you have to either modify the existing pieces or make new mounting hardware so you can anchor the tray to the new cd player.
Old Aug 1, 2005 | 01:01 PM
mrdeadman's Avatar
They let me pick
exactly!
Old Aug 1, 2005 | 05:02 PM
j87w's Avatar
Oh alright then, Im going to try it and get back with you. But the thing that trips me out is it was like this for over a year and then out of no where it just flys out one day.
Old Aug 1, 2005 | 10:02 PM
JAI-DM's Avatar
Do you have an aftermarket stereo? If so, sound like your dash kit is broken.
Old Aug 2, 2005 | 09:25 AM
phateless's Avatar
yeah aftermarket dash kits suck! also, the sleeve for the aftermarket cd player needs to be mounted to the console somehow, not just pressed in. pics would be helpful.
Old Aug 2, 2005 | 09:36 AM
j87w's Avatar
Default Re: (phateless)
Alright, Ill get some pics.
Old Aug 2, 2005 | 09:39 AM
mrdeadman's Avatar
They let me pick
did you get it back in yet?
jdmcd7_cali-luv
Dec 19, 2008 02:05 PM
Bone Stock
Nov 17, 2005 11:39 AM
badnan
Audio / Security / Video
Sep 19, 2002 12:48 PM
94LSTEG
May 29, 2002 06:54 PM
