How the hell do you get the bottom nuts off the Greddy manifold?
Old Feb 19, 2002 | 06:18 PM
hatchy's Avatar
Default How the hell do you get the bottom nuts off the Greddy manifold?
If you installed your Greddy turbo yourself, you should know the answer to this...
What is the trick to get the bottom nuts off the exhaust manifold? There are very small openings near the top, and the opening isn't large enough to work a wrench, and there doesnt seen to be access from below either.
Thanks
Old Feb 19, 2002 | 06:19 PM
immortal's Avatar
Banned
Default Re: How the hell do you get the bottom nuts off the Greddy manifold? (hatchy)
unlatch the turbo off and take off the turbo.
[Modified by immortal, 7:21 PM 2/19/2002]
Old Feb 19, 2002 | 06:36 PM
Phantom's Avatar
Default Re: How the hell do you get the bottom nuts off the Greddy manifold? (immortal)
excellent diagram
Old Feb 19, 2002 | 06:53 PM
89civic1.8T's Avatar
Default Re: How the hell do you get the bottom nuts off the Greddy manifold? (Phantom)
Make sure you are using a 12 pt box end wrench. It's tight but not imposable..after all how did it get on?
Old Feb 19, 2002 | 07:44 PM
hatchy's Avatar
Default Re: How the hell do you get the bottom nuts off the Greddy manifold? (89civic1.8T)
I got the car with the turbo already installed. Thanks for the pointer immortal!
imbest123
22
Jun 29, 2010 05:59 AM
Liquidgsr
Oct 31, 2007 08:55 PM
got_boost16
Jan 31, 2006 07:29 PM
maxoutracer
Aug 2, 2005 05:41 PM
