HELP need help wiring a Volt Gauge
Old Jul 31, 2005 | 05:19 PM
MSBDX's Avatar
Default HELP need help wiring a Volt Gauge
just like the title says its a autometer volt gague and i cannot figure out how to wire it. its going on a 98 civic DX THANKS
Old Jul 31, 2005 | 05:56 PM
Sean Juan's Avatar
Default Re: HELP need help wiring a Volt Gauge (MSBDX)
it should have directions. its one of the easiest ones to install. wire it up to ur 12v on the radio.
Old Aug 1, 2005 | 07:22 PM
MSBDX's Avatar
Default Re: HELP need help wiring a Volt Gauge (GRIP KING)
it didnt come with instructions, can i just wire it to the pos and neg of the cirgette lighter?
Old Aug 1, 2005 | 07:33 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
^ yes but if you;re worried about not cutting the OE hanress like me, just crimped a spade connector on the wires, go under the dash, look for the fusebox underneath and get a test light and check which empty fuse terminals are 'accessory-only' terminals and stick it in there- if you don't know what I'm talking about then just stick with your method
Old Aug 2, 2005 | 05:50 AM
MSBDX's Avatar
Default Re: HELP need help wiring a Volt Gauge (BrokeAssPinoy)
ok thanks
97Ej6
Feb 27, 2007 10:18 AM
used2bedomestic
Jun 17, 2005 07:49 AM
lean
May 10, 2005 12:25 PM
2fast4udude
Mar 8, 2005 03:18 PM
