DA rear bumper removal SEARCHED
4 screws, two on each side..you prollly found those
two lower mounting nuts and two upper mounting nuts...
one of each on each side..
so 4 screws and 4 nuts and the helms service manual pwns joo...
pg. 20-78
im really nice..ill give you the steps from helms..
1. remove the two bumper mounting screws on each side at the corner edge of the bumper.
2. remove the rifht mantenace door and disconnect the license light wire connector.
3. remove the two upper bumper mounting nuts from the trunk area.
4.remove the screws, then romove the under protectors on each side from under the hood.
5. remove the two lower bumper mounting nuts from under the trunk floor.
6. pull out the wire harness from the trunk area and removethe bumper by sliding it to the rear.
NOTE: do not damage the threads of the bumper bolts.
if necessary:
7. remove the scews, then remove the corner slide and slide clip...
pg. 20-78
if necessary:
