Suspension & Brakes Theory, alignment, spring rates....
Ground Contorl Coilover
Old Jul 31, 2005 | 04:36 PM
lavo81's Avatar
Default Ground Contorl Coilover
if i dont lower the car too much will it b ok for say 6-8 months w/o struts? ( my stock suspension really sucks and is very hard and high, and corners like crap. (95 civic hatch cx)
Old Jul 31, 2005 | 04:43 PM
STNDOUT's Avatar
Default Re: Ground Contorl Coilover (lavo81)
Ground Control's are a great coilover, I definately recommend them to anyone, I drove them without changing out struts on my 2000 Eclipse for about a year and ride was smooth, had no problems (but my camber) at about a 2.75" drop.
As long as you don't slam it you should be ok.
Old Aug 1, 2005 | 05:21 AM
lavo81's Avatar
Default Re: Ground Contorl Coilover (STNDOUT)
wow ok i hear there are different types of gc for differnt struts like ones that fit koni and other gc's fit other types of struts will they all work w/ stock struts?
Old Aug 1, 2005 | 06:11 AM
STNDOUT's Avatar
mine did when i bought them for the eclipse.. now i have some for my 92 hatch that i haven't put on yet, but they fit tokico/kyb's..
Old Aug 1, 2005 | 08:03 AM
lavo81's Avatar
Default Re: (STNDOUT)
this is what i asked one of the sponsers : " im planning on getting shocks later but for now if i got Ground Control coilover, the ones for koni shocks would they work w/ my stock suspension?"
his response : "no"
Old Aug 1, 2005 | 10:53 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (lavo81)
I ran my ground controls on my stock 94CX shocks (lowered almost 3") for five years without blowing a single one. The car was never bouncy either. Just a few months ago I switched to Koni Sports. When I removed the stockers, they all looked good, and were still very stiff to move.
My advice would be to plug them in, and drive carefully over bumps and pot holes. Streets in Vegas are pretty good, but I've had my share of nasty hits too...
Old Aug 1, 2005 | 12:45 PM
lavo81's Avatar
Default Re: (94eg!)
thanks for the info, my roads around here are pretty bad in spots but i dont plan on lowering my car more than 1.8 in front and 1.6 in rear
Old Aug 1, 2005 | 12:51 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lavo81 &raquo;</TD></TR><TR><TD CLASS="quote">this is what i asked one of the sponsers : " im planning on getting shocks later but for now if i got Ground Control coilover, the ones for koni shocks would they work w/ my stock suspension?"
his response : "no"</TD></TR></TABLE>
That's right. The ones made specifically for Koni will not work on stock shocks. The ones made for stock shocks will only work on Koni's if you get adapters.
Old Aug 1, 2005 | 01:14 PM
lavo81's Avatar
Default Re: (nonsense)
well i decied no to go with koni and go w/ tokico Illuminas, little cheaper and im not autoxing just rr and fun
Old Aug 1, 2005 | 05:37 PM
Budget EJ's Avatar
i just installed my Ground Controls with some KYB AGX's a couple weeks ago. So far I'm loving the ride! Just another set of shocks you may want to consider since there's no special adapter necessary. Best of luck!
Old Aug 2, 2005 | 05:17 AM
lavo81's Avatar
Default Re: (Budget EJ)
thanks for the input
Old Aug 2, 2005 | 10:07 AM
lavo81's Avatar
anyone suggest spring rates for a civic hatch 95 cx? i was thinkin higher in the rear the the front something like front 300 and rear 400 or 280 and 380. looking for good cornnering but some comfort
Old Aug 2, 2005 | 04:57 PM
94eg!'s Avatar
#1 Super Guy
Loved
Only do a higher rear rate if your going to be doing competition driving. If this is for a street car, most people will hate going for rides in it (except your knuckle head friends).
I'm running 400f/250r and the car still handles like a go-kart...
Old Aug 3, 2005 | 05:16 AM
lavo81's Avatar
Default Re: Ground Contorl Coilover (94eg!)
do u have under steer or over steer?
Old Aug 3, 2005 | 03:04 PM
94eg!'s Avatar
#1 Super Guy
Loved
My car has a nice and easy "snap" over-steer when maintaining a speed. I also get the scary "lift-throttle" oversteer, but we all do. I cant tell you about exit "on-throttle" over/understeer because I only have 70hp, and their is no way I could push the car that hard on the street.
One thing to remember though, over/understeer doesn't matter on a street car since you shouldn't drive like that anyways (nevermind if you track/auto-X your car)...
My suspension setup includes many mods though...
24mm front Teg Sway
14mm rear Teg Sway
No strut braces
Koni Sports
GC top hats (front only)
GC coilovers 400f/250r lowered 3"
Korbach frame locks
205/40/16 Dunlop FM-901's set to 32 psi all around
Old Aug 3, 2005 | 03:08 PM
lavo81's Avatar
did u get camber kit??? or all u need is an alignment?
Old Aug 4, 2005 | 04:42 PM
lavo81's Avatar
somone said that camber kits are a myth and i shouldnt bother. he said that just get the toe fixed and i should be fine will i still wear my tiers more than usual?
Old Aug 4, 2005 | 08:07 PM
hawjboi's Avatar
sounds like your not going that low and maybe not low at all but yeah you dont need a camber kit if your only going that low...just get an alignment and you'll be fine...
here is my setup: (btw i drive an integra fyi)
stock 22mm front sway bar
stock 22mm Type R sway bar
Custom top hats front and back
koni Yellows
GC 450f/400r
Old Aug 4, 2005 | 08:56 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (hawjboi)
I have no camber kits, and I'm lowered 3" for 5 years (50k miles). I've only changed tires once, so tire wear is not an issue...
I suggest you get an alignment though. Toe settings are crucial. That makes me a bit of a hypocryte though since I never tought alignment settings. More recently (within the last 6 minths) I replaced my suspension w/ integra susupension, and the car drifts now. I haven't put hardly any miles on it since because I've got to take it in to fix the toe...
Old Aug 4, 2005 | 09:01 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I have no camber kits, and I'm lowered 3" for 5 years (50k miles). ...</TD></TR></TABLE>
We need to change your username to "slammed, y0!"
Old Aug 5, 2005 | 09:14 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">
W3rd!!!
I just can't seem to talk my wife into buying a swap. That leaves me with 70hp to terroize the streets with . I figured I would just make it look cool, and say "**** it" until that glorious day comes...
I don't really know if it's lowered a full 3" or not since I never measured the before and after. I mearly compared measurments of my car (from fender to center of wheel) to a stock 95 EX coupe. The crazy thing is that my stock 89 CRX Si still has a lower roof line than the 94cx... WTF?
ONECLEAN91
12
Apr 29, 2011 06:12 PM
akylem
May 18, 2009 07:20 PM
STNDOUT
Jul 31, 2005 04:38 PM
riceisnicenv
Suspension & Brakes
Mar 16, 2005 10:14 AM
Integra187
Feb 1, 2002 09:52 PM
