crx with zc
Old Jul 31, 2005 | 04:15 PM
speedd2286's Avatar
Default crx with zc
swapped a dohc zc in my 89 crx a couple weeks ago... battery light comes on at about 4k rpms and all my lights get brighter...also my battery doesnt hold its charge...anyone know what the problem is????
Old Jul 31, 2005 | 04:42 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: crx with zc (speedd2286)
Seems like your alternator is going out.
Old Jul 31, 2005 | 05:03 PM
86si's Avatar
Default Re: crx with zc (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Seems like your alternator is going out.</TD></TR></TABLE>
Old Jul 31, 2005 | 06:12 PM
speedd2286's Avatar
Default Re: crx with zc (86si)
alt is brand new...wouldnt thew lights get dimmer if that was the problem not brighter...also before the battery light comes on it kind of hesitates when you step on it then you hit about 4k rpms and it feels like vtec when the battery light comes on....
Old Jul 31, 2005 | 06:15 PM
1G_DX_to_2G_Si's Avatar
voltage regulator?
Sikocivic's Avatar
Check your ground wires. Be sure all 3 of them are tight
Old Jul 31, 2005 | 06:18 PM
speedd2286's Avatar
Default Re: crx with zc (Sikocivic)
voltage regulator...where is that located....3 ground wires?....i know 1 from the battery to the body...from the front of the engine to the body and im not sure where the 3rd is...enlighten me plz
Old Jul 31, 2005 | 06:57 PM
voltage regulator, if im not mistaken, is inside the alternator. it IS possible to get a bad alt. from the start. have it checked at a reputable alternator shop... first i would just meter the car while running, have someone rev the engine while you read it at the batt. it shouldnt fluctuate much it should be around 14.4v all the time
Old Aug 1, 2005 | 08:04 PM
speedd2286's Avatar
Default Re: (1G_DX_to_2G_Si)
so today i reved the engine past 4k rpms and blew out my headlight bulbs...there is somethign deff wrong....
Old Aug 1, 2005 | 08:08 PM
efjiongco's Avatar
try getting your alt checked out, and consider maybe a ground kit, maybe from NRG.
Old Aug 1, 2005 | 09:18 PM
LoneStarCRX's Avatar
Default Re: (speedd2286)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedd2286 &raquo;</TD></TR><TR><TD CLASS="quote">so today i reved the engine past 4k rpms and blew out my headlight bulbs...there is somethign deff wrong....</TD></TR></TABLE>
I'm sorry. That just paints a vivid image.
Isn't that what a vlotage regulator is supposed to prevent?
Old Aug 1, 2005 | 11:52 PM
TheJunBuilt's Avatar
it might be ur starter ground .....if its loose it will spark and wierd **** will dim and ge brighter and all that or ur alt...look at both
Old Aug 2, 2005 | 01:53 AM
Twilight's Avatar
Default Re: crx with zc (SirJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1G_DX_to_2G_Si &raquo;</TD></TR><TR><TD CLASS="quote">voltage regulator?</TD></TR></TABLE>
Exactley.
The lights get their power from alternator, if theyre getting brighter and brighter. What could cause this?
Old Aug 2, 2005 | 05:53 PM
speedd2286's Avatar
Default Re: crx with zc (Twilight)
i was looking online and i found a voltage stabilizer...could that help?....i also ordered a ground kit in hope that could solve it and they also look neat...also was thinking im using the alternator off of my stock si engine...since its a sohc alt on a dohc motor that could be screwing with it?
i_VTEC
24
Jan 19, 2015 03:32 PM
cticknor666
Oct 5, 2006 01:25 PM
siregcivic
Jun 22, 2006 11:15 PM
korean_teg
Sep 30, 2005 08:27 PM
_bB
Jun 11, 2004 06:53 PM
