WTB: I need a TPS harness which is part of the main harness from a Accord/Civic or lude
I am in need of a new harness for my tps sensor it is part of the main relay harness. or If somebody can direct me where to find factory honda wire pins then that will work too. The harnesses yellow wire eas twisted and I quess from years of vibration and heat and weather it shorted out within the wire itself which sucks it fell apart in my hands so if anybody has a left over harness from a swap or anything I will give ya some money I need this asap cause I taped the open wire into the harness and used heat shrink to hold it so I need to replace this quick I have paypal so either pm me or let me know.... thanks
Do you need the tps plug or the main harness plug. If you send me a pix of what part you need, i'm pretty sure I have it. Just let me know.
I need the plug not the total harness I do however need about 10-12 inches of wire so I have something to splice into -- the grey plug with three wires running from it (red, green, and yellow) -- I can send I picture if you need it but you can not miss it -- it plugs straigt into the tps --- let me know thanks
I can get you the TPS plug with correct pins & wires in it as long as you need, I have a spare parts harness sitting around. Make an offer, I can probably ship today if you're in a hurry...
got one from a local honda graveyard thanks though -- just could not wait with an open wire taped through the pin hole I appreciate it though.. mods can lock and delete thread thanks
