driving normal, punch it, hard power, no power, hard power. fuel pump?
Old Jul 31, 2005 | 02:21 PM
EGmikeH22's Avatar
* B A N N E D *
Default driving normal, punch it, hard power, no power, hard power. fuel pump?
so i'll be driving in first, let it get up to 3-4k, then punch it, it'll slam you back into the seat, then hiccup loosing all power like its hitting a rev limiter, then before you can think it just slams you back again and will go all the way through the gears at full power.
is my stock vx fuel pump just not cutting it anymore and it just can't react to that kind of need for fuel?
my fuel filter is original, I have a new one and am currently installing it, but does everyone think i'm on the right track?
Old Jul 31, 2005 | 03:18 PM
The Phil's Avatar
Default Re: driving normal, punch it, hard power, no power, hard power. fuel pump? (EGmikeH22)
VX?
I'm guessing from your username you have a H22 swapped into an EG. I'd suggest using the prelude's fuel system instead of the EG's.
Old Jul 31, 2005 | 03:38 PM
red92s's Avatar
Default Re: driving normal, punch it, hard power, no power, hard power. fuel pump? (The Phil)
I had similar symptoms, and a new fuel filter and plugs cured it.
Old Jul 31, 2005 | 04:23 PM
EGmikeH22's Avatar
* B A N N E D *
i'll just have to find some way to loosten the stock one, I can get the engine line loose, but that feed line is just too tight!
Old Jul 31, 2005 | 07:27 PM
LudeyKrus's Avatar
I can't say for sure, but knowing how Honda and many other import manufacturers like to cut the fuel spec's on the fuel system, I'd say it's time for a new Walbro. Have you tried a wideband?
Old Aug 1, 2005 | 07:03 PM
EGmikeH22's Avatar
* B A N N E D *
i have one, and it doesn't get real lean or rich right before the loss of power.
Old Aug 1, 2005 | 07:11 PM
fastludeh22's Avatar
Default Re: (EGmikeH22)
when was all the normal mataince done on it?
rdssk8rcs1
Apr 22, 2008 07:22 PM
slowteg550
May 4, 2006 05:36 AM
brian3676
Dec 31, 2005 09:58 AM
SVOboy
24
Jul 22, 2005 12:02 PM
dustin
Feb 8, 2002 06:41 PM
