question about dash swap
Funny you ask that, because I just put a 2001 Integra Type R dash on my race CRX. It is the same dash as all the 94 and newer integras and it doesn't fit on the CRX. the only reason I puty it in, is because I got tired of having no dash.
the thing is completely gutted on the inside, no AC, no fan no nothing.
So, if you want to put another car's dash you ned to stay within the EF family.
I think the hatchback will work with your AC stuff.
Good luck
Good luck
There was a guy several months back that had put a 3g teg dash and center console in either a CRX or a hatchback. I don't remember who it was but with some careful searches you should be able to find it. So yes it can be done. No it is not a direct bolt in.
someone did post that someone they knew did it and it looked like **** the door panels wont line up and itll be alot of wiring for the cluster so i wouldnt do it
yeah u can put it in but u have to get new door panels if u want it to look right and u have to cut part of the dash so it will fit in but i think its tooo much work for a new look just get jdm cluster or somthing
xsellxoutx
11
Dec 29, 2003 09:46 AM
synergy-blue
Nov 14, 2001 11:15 AM
