Flat faced valves.
Old Jul 31, 2005 | 01:23 PM
1999all_motoR_teg's Avatar
Default Flat faced valves.
Just wondring on the average how much do flat faced valves raise your compression??
I have a JDM ITR motor 11:1.1 and will be building my head and was wondering how high my compression will be around when installing these.
ALso I plan to mill the head 10-20 thou and use a 2 layer headgaket.
I tried calculating it on c-speed but I really suck at math and numbers in general. Can someone help out please and give me a rough idea of what my compression will be about.
TIA
Modified by 1999all_motoR_teg at 10:43 PM 7/31/2005
Old Jul 31, 2005 | 02:22 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Flat faced valves. (1999all_motoR_teg)
Flat faced valves will add about .2 bump in compression. A 2 layer head gasket will also net you about .2-.3 bump in compression. For every .010 thou that you remove off the head or deck (block) you'll increase the comp ratio by about .2 as well. Add up whatever you do on top of what the known compression ratio is and you'll have a final number.
Old Jul 31, 2005 | 06:01 PM
Default Re: Flat faced valves. (00Red_SiR)
Thanks for the info. So if I got my compression up to about 11:5.1-11:7.1 do you think that would be enough compression to run Skunk2 Pro 1's or BC Spec IV's???
Old Jul 31, 2005 | 06:18 PM
sheepey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info. So if I got my compression up to about 11:5.1-11:7.1 do you think that would be enough compression to run Skunk2 Pro 1's or BC Spec IV's???</TD></TR></TABLE>
yes
Old Jul 31, 2005 | 06:21 PM
EK Josh's Avatar
Default Re: Flat faced valves. (sheepey)
Just for reference: I emailed buddy club and they told me all that's recommended for spec IV's was 10.5:1 compression, but obviously the higher the better.
L_K
25
Mar 9, 2007 07:52 AM
AlwayzSpoolin
Jan 17, 2007 05:53 PM
ticket_target
Nov 11, 2006 11:26 AM
EG type GTR
Aug 13, 2006 09:05 AM
zoom545
Nov 22, 2005 09:04 AM
