Suspension & Brakes Theory, alignment, spring rates....
New setup too bouncy???
Old Jul 31, 2005 | 10:51 AM
Powered By Garrett's Avatar
Default New setup too bouncy???
I recently got my suspension installed:
95 DX Hatch
Koni Yellow Adjustables
Neuspeed RACE Springs (used)
When I got the car is was horribly bouncy, I slowly adjusted the firmness of my shocks more and more till finally I had them at max stiffness, and the car is still pretty bouncy. Do you guys have any suggestions?
ALSO! My springs don't sit "straight" under my car, they are straight up and down when the car is up on jacks, but on the ground the kinda 'curve' like a c-shape on the shock.
Thanks in advanced
Old Jul 31, 2005 | 11:04 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: New setup too bouncy??? (SonicEG)
Make sure the springs are seated properly.
Old Jul 31, 2005 | 11:23 AM
Default Re: New setup too bouncy??? (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the springs are seated properly.</TD></TR></TABLE>
I don't know crap about suspension , I had it done, what would I be looking for?
Old Jul 31, 2005 | 03:50 PM
superdupervtec's Avatar
I had those springs and changed to eibachs, It fixed the problem.
Old Aug 12, 2005 | 01:26 PM
mdd's Avatar
mdd
Default Re: New setup too bouncy??? (superdupervtec)
hey sonic! the springs fixed yet? or are they still having problems I talked to you before remember. Anyways hopefully things are going well now let mek now
Old Aug 12, 2005 | 02:21 PM
Default Re: New setup too bouncy??? (mdd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdd &raquo;</TD></TR><TR><TD CLASS="quote">hey sonic! the springs fixed yet? or are they still having problems I talked to you before remember. Anyways hopefully things are going well now let mek now</TD></TR></TABLE>
Eh, there getting a bit better, they are only really bouncy on some roads, but i'm probobly going to switch to colovers.
Old Aug 13, 2005 | 08:41 PM
mdd's Avatar
mdd
wanna sell me ur konis so i can try em
Old Aug 13, 2005 | 09:28 PM
superpilun's Avatar
If you really care and want to fix this, you should jack the car up, take off the wheels, take out the struts and springs, and make sure the springs are seated correctly, and check for other things. As for bounciness, if adjusting the koni's did nothing, you might be sitting on the bumpstops.
Old Aug 13, 2005 | 11:58 PM
Default Re: New setup too bouncy??? (superpilun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun &raquo;</TD></TR><TR><TD CLASS="quote">you might be sitting on the bumpstops.</TD></TR></TABLE>
What does that mean? I hear the word bumpstop so often .
I was thinking about getting some Ground Control coilovers that are made for the Koni shocks, would this most likely be an improvement?
guitarguru87
10
Jan 2, 2009 11:39 PM
stripes777
Suspension & Brakes
Sep 20, 2006 12:30 AM
minivanman
Honda S2000
Jun 7, 2004 10:31 AM
i
Mar 7, 2004 09:40 AM
grlstockb18c1
May 15, 2003 03:52 PM
