B20Z detonating after timing belt/other service
Hey gurus--
The B20Z in my wife's 99 CR-V is detonating after doing a service on it which included:
Change timing belt/water pump
change tranny fluid
change brake fluid
clean K&N
valve adjustment
It now detonates under load. I know we didn't let the camgears move over a tooth--as evidenced by the car's perfect idle and newfound pep.
Any thoughts on what the hell could be happening?
change tranny fluid
change brake fluid
clean K&N
valve adjustment
I'm willing to bet lots of money the belt is off by a tooth. Same thing happened to a Civic HX A buddy and I did a service on. It detonated under load and didn't make much power. Check the timing marks on crank with the cam pulleys.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Educator »</TD></TR><TR><TD CLASS="quote">I'm willing to bet lots of money the belt is off by a tooth. </TD></TR></TABLE>
Chev
Jul 23, 2018 10:56 AM
LoveDeezNutz
Mar 10, 2011 07:27 PM
