Weird vibration coming from my motor...Help!
When my car warms up ('95 EG) the motor vibrates, then stops, vibrates, stops etc... The RPMs are not climbing when this is happening. Anybody have an idea whats going on?
YOu using stock mounts and bushings? Stiffer than normal mounts MIGHT cause somethign liek this....it really depends on persoanl perception though....I mean I'm using Mugen mounts and my **** vibrates a fair bit.
Thats odd....neither of thsoe should have affected engein vibration. Unless its causing driveability problems I wouldn't worry about it.
yep, I'd crawl under there and start checking mounts. I've got a mount that's getting ready to go out and every once in a while I get a little shake action.
Bear in mind that FWD transaxles shake alot more than a stadard RWD car anyway....I was watching my old LS run throught the gears when we had it up on a lift...that ****** moved alot!!
boostedb16a3
13
Feb 24, 2006 03:12 PM
