How do I take out my '03 accord cd player?
I think if you turn the radio off and then hold down 1 and 7(?) and turn it on it will tell you the model number and serial number, someone correct me if i'm wrong. Also, go here https://honda-tech.com/zerothread?id=1084720 once you find the numbers, he can tell you the code
That worked... sort of. It gave me 2 number sets, one said L with 4 numbers, the other was U with 4 different numbers. Also, when I pressed 1-1-2 my radio suddenly popped on, but only until I turned it off, I had to do the same thing to get it back on.
if that stuff doesn't work it's a pain getting that radio out. you have to take out the pocket underneath the radio and the vents above the radio and there should be bolts/screws that hold the whole radio/climate control unit.
nrussell
Apr 11, 2006 12:21 PM
