Anyone have an Air Cond. unit for the type r for sale and any experience installing?
Old Feb 19, 2002 | 03:46 PM
typer464's Avatar
Default Anyone have an Air Cond. unit for the type r for sale and any experience installing?
I
Old Feb 19, 2002 | 03:47 PM
ThePunk's Avatar
Default Re: Anyone have an Air Cond. unit for the type r for sale and any experience installing? (Jpwill21)
Talk to bob#497.
Old Feb 19, 2002 | 03:49 PM
typer464's Avatar
Default Re: Anyone have an Air Cond. unit for the type r for sale and any experience installing? (ThePunk)
i already did and he made me a good offer but i just want to see who else is selling one as well see how hard it is to install it
[Modified by Jpwill21, 12:52 AM 2/20/2002]
Old Feb 19, 2002 | 03:55 PM
yoshi234's Avatar
I shoot brides
not sure how hard it is to install but I know of an ITR owner that removed his AC this past weekend. I"ll have hime IM you in a sec.
The parts are in OC right now
yshi
Old Feb 19, 2002 | 03:56 PM
Bob#455's Avatar
How much for the dealer to install it?
Nick, I just called the local dealership and they said that labor for the install is $425. I helped a friend uninstall his, and it did not seem too complicated. Pretty much everything came off with a set of metric sockets, and I would assume it goes back in much the same way. I believe it took 2-3 to uninstall, so I'm guessing 4-6 to install...maybe someone here who has done it can give you a better estimate.
Old Feb 20, 2002 | 12:32 AM
itRgirl's Avatar
well i don't use my a/c but my car in the body shop.. i have done a lot of a/c work, ase certified but never on an acura.. shouldn't be hard if everything interchangable.. there a spot for the a/c switch in the dash? not sure if the system would have to be opened but i will go see my car and look...
Old Feb 20, 2002 | 12:28 PM
typer464's Avatar
Default Re: Anyone have an Air Cond. unit for the type r for sale and any experience installing? (itRgirl)
are
Old Feb 20, 2002 | 07:56 PM
Bob#455's Avatar
there is a spot on my dash for the button, i just need the button, its just a block filler
thanks for the help
nick
I don't think you need any special tools...just wrenches/sockets/screwdrivers. There are a few parts that need to be traded to make it work. For instance, you would send me your blank button, and then I send you my AC button.
Old Feb 20, 2002 | 08:10 PM
Chris's Avatar
Default Re: Anyone have an Air Cond. unit for the type r for sale and any experience installing? (Bob#497)
and the "bridge" to put where the condenser was, and vice/versa
depends on the year the AC is going into (94's need a different relay)
Ask me a specific question and I will answer it. Bob will also include instructions on how to add it.. very detailed (from the dealer).
Old Feb 20, 2002 | 08:13 PM
Bob#455's Avatar
Default Re: Anyone have an Air Cond. unit for the type r for sale and any experience installing? (Chris)
The parts from '98 to '01 should all be directly interchangable, right?
Old Feb 20, 2002 | 08:16 PM
Chris's Avatar
DIRECTLY. even the button! (the button from a 94 is black, not the gray-ish color like the 98+)
Old Feb 20, 2002 | 10:38 PM
Chris's Avatar
Its extremely easy! Instructions that will be included are simple.
Should take a couple hours. You will need to get it charged at a shop though. If you buy Bobs, I will personally make sure the ends are sealed once removed to make sure no condensation enters the lines during shipping (that will cause more time and $$$ when charging the system, as the condensation/moisture needs to be removed completely from the system).
Acura reccomends you lube the o-rings with lube made for the AC system, that stuff is real expensive, and unnecessary because this system will be freshly removed. In my opinion, its only needed on brand new o-rings, that have never been exposed to the refrigerant.
Anything else, let me know. I will try to answer them for ya.
Old Feb 21, 2002 | 03:02 AM
tecnic1's Avatar
tell me about this bridge where the condenser was? where does it go? I just took the condenser out. What should I be looking for since I didn't use one?
Old Feb 21, 2002 | 09:57 AM
Bob#455's Avatar
Default Re: Anyone have an Air Cond. unit for the type r for sale and any experience installing? (tecnic1)
It's basically an empty pathway that allows the air to enter the vent system... The "bridge" allows the air to pass through, while the condenser allows the air to be refridgerated before passing through (thus giving you AC).
Old Feb 21, 2002 | 06:16 PM
tecnic1's Avatar
Where does it go? under dash? I'm really slow. and lost here
Old Feb 21, 2002 | 06:26 PM
Chris's Avatar
It goes where you took out your condenser...
from the Blower to the vents. Under the dash (behind the glove box)
Old Feb 21, 2002 | 06:59 PM
tractoy's Avatar
I'll sell you mine. Make me an offer. I don't think it was ever turned on I also have th Helm manual, and can copy the section you need for the install.
E-mail me at tractoy@comcast.net or call me at 703-519-3523
Chris
Old Feb 25, 2002 | 03:14 AM
tecnic1's Avatar
thank you..
crxguy406
Jul 19, 2014 09:50 AM
NiKKa NiKKy
Texas -OK -LA (Sales)
Jan 24, 2013 02:16 PM
JMod
Oct 19, 2003 11:03 PM
typer464
Jan 28, 2002 08:18 AM
