Weather's Hot, Car Doesn't Start... HELP
Old Jul 30, 2005 | 02:06 PM
fms1day's Avatar
Default Weather's Hot, Car Doesn't Start... HELP
Okay, so I went to start my car today but when I tried to turn it on, it would crank but it wouldn't turn over. I noticed that I didn't hear any fuel prime when the key was turned to the 'on' position... and no click after the CEL light goes off... So I'm guessing its the fuel pump? Or the Main Relay? If it's the fuel pump, what could it be that's making the fuel pump unable to prime fuel, because I don't want to remove the backseats and carpeting just to stare at the fuel pump, not knowing what to look for. And is it possible that it's a bad Main Relay?
btw... this is for a '92 Hatchback CX
thanks.
Old Jul 30, 2005 | 02:29 PM
damnraz's Avatar
Default Re: Weather's Hot, Car Doesn't Start... HELP (fms1day)
check your main relay, that's my best bet if you're fuel pump doesn't kick on and etc.. happens to my nephews car quite often.
Old Jul 30, 2005 | 02:40 PM
CRXified's Avatar
Default Re: Weather's Hot, Car Doesn't Start... HELP (damnraz)
definatly the main relay, happened to me on my CRX and my last civic. u need to take it out and put some new solder on the cracked points, ill find u a link... **** the link doesnt work anymore, im sure u can find it on here, just search main relay
Old Jul 30, 2005 | 03:02 PM
fms1day's Avatar
Default Re: Weather's Hot, Car Doesn't Start... HELP (CRXified)
yeah i've heard about re-soldering the main relay joints. If anyone has it, can they show me a comparison picture of a joint that's 'perfect' and a joint that's 'cracked'?
Old Jul 30, 2005 | 03:31 PM
fms1day's Avatar
it was the main relay... swapped it with another one and it primed and started just fine.. thanks guys...
Old Jul 30, 2005 | 04:40 PM
CRXified's Avatar
nice
PatrickFrantz
Aug 21, 2008 05:53 AM
blaze_125
Jun 16, 2008 08:15 AM
stuntinhb
Mar 4, 2007 02:59 PM
shoebox
Feb 11, 2004 11:18 AM
RenoRacing
Sep 8, 2002 09:41 PM
