question for itr owners
Old Feb 19, 2002 | 03:38 PM
Frito1's Avatar
Default question for itr owners
i have a 98 gsr, if i put a itr header, itr cat, and itr muffler, will i gain more hp over my stock system. i want performance but i want the sleeper look and quietness. is the cat and muffler restrictive. thanks for info.
Old Feb 19, 2002 | 03:48 PM
Black R's Avatar
25 Year Member
Default Re: question for itr owners (tegsleeper)
.....you will experience gains over your stock setup. How much? I don't know. Try it and see. oe reliability and quietness... sleeper look
Old Feb 19, 2002 | 04:09 PM
Padawan's Avatar
Darth ModerVader
JDM ITR 4-1 w/ heatshields, Carsound 2.5" cat., and ITR exhaust with the bottleneck at the cat./b-pipe connection removed will provide nice gains and maintain a stock look and basically stock sound. Don't bother with the USDM ITR manifold or cat. - both are .
Old Feb 19, 2002 | 04:27 PM
Bob#455's Avatar
Default Re: question for itr owners (SpecR0123)
Yes, that is a better setup, but it will cost way more money. I think the ITR header/cat/exhaust setup is good for a couple whp on a GS-R, and that entire setup should cost him less than a JDM ITR 4-1...
Old Feb 19, 2002 | 04:28 PM
Frito1's Avatar
will everything bolt right up to my 98 gsr. will the piping run under the car the same way or will i have to modify .thanks.
Old Feb 19, 2002 | 04:44 PM
Bob#455's Avatar
I'm not positive...but I believe if you are installing the ITR header, cat, and exhaust it will all bolt right up. If you try to install only parts of the complete exhaust system, it won't work with the existing GS-R parts. Any GS-R people want to confirm/deny this?
Old Feb 19, 2002 | 04:49 PM
CKim's Avatar
Default Re: question for itr owners (Bob#497)
I concur. If you go with the whole H/E/cat, everything should bolt right up. Otherwise, the collector on the header and the b-pipe are too long.
[Modified by CKim, 12:12 AM 2/20/2002]
Old Feb 19, 2002 | 06:15 PM
Padawan's Avatar
Darth ModerVader
On a tighter budget, you would probably be better off keeping your stock GSR manifold and installing a 2.25" Carsound cat., removing the first bottleneck on the stock b-pipe, and running an ITR axle-back. The ITR manifold simply isn't enough of an improvement to justify buying it, and the ITR cat. is very unimpressive as well.
BTW - I'm not trying to discourage you, and if you are set on getting the ITR setup then by all means do. However, for the roughly $300 or so the setup would cost, there are other mods that would likely provide better gains. I'm not sure of your current setup but a CAI, a set of cam pullies tuned on a dyno, or a used vtec/fuel controller w/ tuning would likely provide better gains and would be more useful with future mods. HTH and good luck.
[Modified by SpecR0123, 10:40 PM 2/19/2002]
Old Feb 19, 2002 | 07:31 PM
YellowR2000's Avatar
New User
from everything ive seen and heard im not sure the exhaust will bolt on...main reason behind this is alot of people around bolt stuff on and take stuff off all the time and sell it and the type R exhausts that come off are R and LS compatible but everyone says its not gs-r compatible, dont know for sure but worth looking into..
Old Feb 19, 2002 | 08:06 PM
CKim's Avatar
Default Re: question for itr owners (YellowR2000)
YellowR is right... the cat-back will not bolt up. But he's talking about getting the header, cat, and exhaust. With the ITR header and cat, the cat-back should bolt up no problem.
Old Feb 20, 2002 | 01:22 PM
Frito1's Avatar
Default Re: question for itr owners (CKim)
thanks a lot everyone
sohctodohc
May 15, 2007 08:43 AM
JDM_Ej
Apr 16, 2005 11:09 AM
SloEG
Nov 18, 2003 03:03 PM
