ViS Lip: Fitment Issues.
Old Jul 30, 2005 | 11:36 AM
SoCal EJ1's Avatar
Default ViS Lip: Fitment Issues. [EDIT: pix of it installed =)]
I just got a ViS front lip for my '95 coupe and it doesn't seem to fit very well. I dont have pix yet, but I'll do my best to explain it...
Basically, when one side is on, only about half the front wants to sit flush, and the other side is competely crooked and off. If I manage to get both sides pressed into place, the whole front is completely off and not even close to being flush. None of the mounting points make contact.
Did I get a bad lip, or is this just ViS quality? Should I exchange it or just have a body shop install it?
I searched new and archived forums and found nothing...
Modified by SoCal EJ1 at 3:26 PM 7/31/2005
Old Jul 30, 2005 | 11:48 AM
SoCal EJ1's Avatar
Plenty of views, no input?
Old Jul 30, 2005 | 12:08 PM
B.'s Avatar
B.
400 HP Club
Default Re: (SoCal EJ1)
I know with mine I had to force it on the one side.. Set up your ends first then work your way in using the stock lip as your guide.. I'd use self tapping screws to secure the lip in place.. After all that if its still giving you problems return it or like you said have a body shop look at it..
Old Jul 30, 2005 | 12:28 PM
SoCal EJ1's Avatar
Default Re: (B.)
Shouldn't I just be able to use the same screws that hold the oem lip on?
Old Jul 30, 2005 | 06:24 PM
turbo95eg6's Avatar
I dont know what the deal with their lips are....everytime i put one on the CF clear coat cracks on me because yu gotta force the ******* on there
Old Jul 30, 2005 | 07:04 PM
305JDM's Avatar
Default Re: (turbo95eg6)
my seibon was like that it didnt want fit and i didnt want to crack it...so i took it to a bodyshop and got it to fit...
Old Jul 30, 2005 | 07:24 PM
JDM knowledge's Avatar
Default Re: ViS Lip: Fitment Issues. (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
It's VIS you take your chances. Take some double sided tape and a screw gun to that **** and call it a day.
Old Jul 30, 2005 | 09:28 PM
Revtek 2's Avatar
I had the same issue with my VIS lip, I thought that it didn't fit at first but the more I looked at it I figured it out... I thought that it was suppose to line up with the line that goes around the bottom of the bumper but mine doesn't (I looked at a lot of EG's and EJ's on this site to see if their VIS lip lined up with that line and I noticed that some lips did while others didn't).
The easiest way to do it is to get take your bumper off and lay it upside down on the ground, then place the lip on top (remember not to follow the line on the bottom of the bumper cause if you try to flex it to make it fit it will crack). Then take some white out and mark the lip through the holes on the bottom of the bumper. Once you have the holes marked you can drill it, but don't drill the holes too big just enough for the threads of the screws to fit (I got my screws from Home Depot, you can take one of the clips from the bottom of the bumper to the screw section and just find the screw that best fits).
Don't be scared to drill into the lip, just as long as you don't apply too much pressure to it you'll be fine and don't use too wide of a bit cause you can always make the hole bigger later. If you do happen to drill the hole bigger than the head of the screw you can always get the ring spacers that go between the screw and the bottom of the lip. Depending on how on-point you were with the marking of the lip with the white out, you might have to widen the holes on the lip so you can get the screws to fit into the bumper.
Altogether I have 5 screws holding on my lip... 2 at each corner, 1 in the middle, and 1 between each corner and the middle. Hope this helps...
Old Jul 31, 2005 | 02:25 PM
SoCal EJ1's Avatar
Thanks for the input guys. With a little... no, lot of effort, I managed to get it installed. Looks about 95% fitment now. Here are some pix.
Now all I have to do is lift the front up a tad and get my JDM fenders wired and painted...
Old Jul 31, 2005 | 02:31 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the input guys. With a little... no, lot of effort, I managed to get it installed. Looks about 95% fitment now. Here are some pix.
Now all I have to do is lift the front up a tad and get my JDM fenders wired and painted... </TD></TR></TABLE>
looks sick man
Old Jul 31, 2005 | 02:32 PM
Phil DeVtec's Avatar
Default Re: ViS Lip: Fitment Issues. [EDIT: pix of it installed =)] (SoCal EJ1)
VIS fits fine for me!
2000EJ8
Paint and Body
Sep 12, 2010 12:03 AM
jdmjunkieXL
Dec 3, 2006 07:11 AM
sk8shorty012
Feb 6, 2006 06:06 PM
SovXietday
Jan 1, 2006 10:13 AM
honda_coupe
Nov 1, 2005 04:20 PM
