Suspension & Brakes Theory, alignment, spring rates....
CRX rear disc swap = horrible alignment...
Old Jul 30, 2005 | 10:27 AM
paopao's Avatar
Default CRX rear disc swap = horrible alignment...
Alright, so I just finished putting 94 Integra LS rear discs on my 1988 CRX Si. I'm pretty sure I installed everything correctly but I have one major problem. The passenger side looks great, no major alignment problems at all. But the driver's side has massive toe in and disgusting positive camber. What could have caused this?! I used the CRX compesator arms and the CRX UCA's. I'm clueless and I don't think a simple alignment will fix it...
I'll let the pics do the talking:
Passenger side:
Driver side:
Old Jul 30, 2005 | 10:37 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: CRX rear disc swap = horrible alignment... (paopao)
do you go to iit?
Old Jul 30, 2005 | 10:42 AM
paopao's Avatar
Default Re: CRX rear disc swap = horrible alignment... (cbmprelude)
I did last year, but that's OT. Someone help me before I start swapping trailing arms...
Old Jul 30, 2005 | 11:04 AM
paopao's Avatar
Someone? Anyone?!
Old Jul 30, 2005 | 11:43 AM
Tyson's Avatar
looks like accident damage. sorry bud.
Old Jul 30, 2005 | 12:55 PM
stormy's Avatar
Default Re: CRX rear disc swap = horrible alignment... (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">looks like accident damage. sorry bud.</TD></TR></TABLE>
the trailing arms from the DC will cause this on a crx. There should be some thread links at the top of the crx forum.
I believe a fix for this is to have the hubs pressed out on the stock trailing arms and use the DC's - not 100% on this but ask around in that forum
Old Jul 30, 2005 | 12:58 PM
Tyson's Avatar
Default Re: CRX rear disc swap = horrible alignment... (stormy)
BS. this is the REAR suspension, chief.
if anything the integra rear LCA is going to give negative camber. the driver side is obviously fucked up compared to the passenger side, which looks fine.
accident damage. no LCA speculation, please....
Old Jul 30, 2005 | 01:18 PM
paopao's Avatar
Is it possible to just swap the disc assembly over to the old CRX trailing arm? I'm pretty sure the arms are the same.
Old Jul 30, 2005 | 03:05 PM
paopao's Avatar
This sucks, but looks like I'm just gonna have to swap the disc assembly over to my old CRX trailing arms...
Old Jul 30, 2005 | 06:31 PM
stormy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paopao &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to just swap the disc assembly over to the old CRX trailing arm? I'm pretty sure the arms are the same.</TD></TR></TABLE>
the dc ones should be a bit longer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">BS. this is the REAR suspension, chief.
either way chief since there were x's on the right side pix last time the fix is still the same.
Old Jul 30, 2005 | 06:40 PM
b20bvtec'd's Avatar
I had a similar problem did you reuse the crx compensator arms? I think that could be the problem.
Old Jul 30, 2005 | 07:10 PM
d16dcoe45's Avatar
It is possible to swap just the disc part--there are 4 or 5 tight torx bolts you will have to undue (they are TIGHT) and you just switch spindles--if your car had better alignment with your crx trailing arms, this is your best bet...
Old Jul 30, 2005 | 07:31 PM
ATS_Antone's Avatar
Default Re: CRX rear disc swap = horrible alignment... (d16dcoe45)
the trailingarms are ok. you have to swap back to the crx compesator arms
(not sure what they are called) but they are the short ones in front.
Old Jul 30, 2005 | 08:03 PM
paopao's Avatar
Default Re: CRX rear disc swap = horrible alignment... (antone)
I used the original CRX compensator arms. They never came off the car, that's why I started taking the spindles off, and broke the cheapo Torx bit from Pepboys .
Modified by paopao at 8:18 AM 7/31/2005
Old Jul 30, 2005 | 08:50 PM
King-Kong's Avatar
ok what you need to do is use the compensation arms off your original brakes (thats the short little arm located off the trailing arm closest to the front of the car) and remove the integra one and swap them over. secondly, you can adjust that negative toe by loostening the compensation arm bolt located on the chassis of the car (14mm i believe) and pivot it in or out then tighten to where you feel is pretty close to perfect then once you are somewhat able to drive the car take it down to an alignment shop and get a 4 wheel alignment and you should be set, if you need any help just im me and i'll try to help you out the best i can. I have been in this boat before and learned the hard way.
Old Jul 31, 2005 | 05:19 AM
paopao's Avatar
Default Re: (turbo_CRX)
Bump it up for swapping trailing arms at 8:16 AM.
Old Jul 31, 2005 | 08:17 PM
pearlcfcivic97's Avatar
That sucks man, I hope i dont have that problem with mine when i do it...
Old Jul 31, 2005 | 09:09 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Thats just horrible Didnt the trailing arm look bent or anything out of the ordinary before u put it on? I say just find another trailing arm and dont even **** with changing spindles. U paid for 2 good trailing arms and u should get 2 good arms. Return it and get another. Well, assuming u got it from a junkyard and all.
Old Jul 31, 2005 | 09:27 PM
paopao's Avatar
Default Re: CRX rear disc swap = horrible alignment... (rukawa1one)
Yeah I know. I actually got it from a local member here on HT. I specifically asked him if the trailing arms were bent or anything, and he told me "No, of course not." Just goes to show who you can trust nowadays .
And to answer your question, no the trailing arm didn't appear to be different at all. It really sucks because even though it looked fine, the deformation was just enough to **** it all up.
Old Aug 1, 2005 | 02:51 PM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paopao &raquo;</TD></TR><TR><TD CLASS="quote">And to answer your question, no the trailing arm didn't appear to be different at all. It really sucks because even though it looked fine, the deformation was just enough to **** it all up.</TD></TR></TABLE>
It's usually the hub/spindle that bends in those, so the arm will usually look ok, even though it isn't. If you can swap the hubs out cheaply, that may be another option of going.
Old Aug 2, 2005 | 01:26 PM
mike-y's Avatar
ouch, that's definately a bent trailing arm. same thing happened to me actually. it can be really hard to tell the arm is bent until you get it on the car, since only a little bit out at the hub will be exaggerated once the wheel is put on.
the wrong compensator arms should only affect toe, not camber. I personally helped install 95 integra rear trailing arms, brakes, and lower control arms on an 89 civic and its fine with the civic/crx front compensator arm.
you can swap the hub assembly over to your CRX trailing arms though, like said above. theres like 5 bolts holding it on from the back of the arm, you'll need a big air gun to pop them loose. then just transfer them over to your CRX arms. and you might want to press in a new oem trailing arm bushing while you have the arms off the car too.
good luck.
chrisb
Jan 30, 2006 09:33 AM
mr.roboto
Sep 26, 2005 02:19 PM
9crx1
Jun 15, 2004 11:17 AM
