obd0 to obd1
I NEED MADDDD HELP ON THIS ONE... to do an OBD0 to OBD1 MPFI conversion on my 90 CRX dx will i need the wiring harness that is in the interior of the car as well? (the part that hooks up to the fuse box inside of the car) i have the engine bay harness from a 92-95 civic but i wasn't all too sure if that's it... help me, helpme pleeeez!
You re-use your stock DX harness, since the 1995 harness has completely different wire locations in the shock tower plugs, and will not work with your chassis harness. You have to convert your DX harness to MPFI, and then after that you splice in the OBD-I distributor plugs and do some other light wiring - depending on your engine, etc.
4gencivicef9
Jun 6, 2008 07:48 PM
psychadelicfreedom
Jul 2, 2005 11:22 PM
