92 hatch w/ b18b. I've got questions
Old Jul 30, 2005 | 12:58 AM
steelies's Avatar
Default 92 hatch w/ b18b. I've got questions
I've come across a great deal. A clean, straight 92 hatch w/ a low mileage b18b swaped in. Only thing is it's got an auto tranny, and the stock d15 ecu and such still.
My question is, what ECU could I buy and install to make it work? P75? Like what the b18b has got in the integra lower end models.
I'll also be swapping in my 5speed. I'm assuming I'll need a new mount or two?
Other than that. Will it be a pretty direct replacement for the trans, and ecu other than getting it all in and wired up, and bolted down?
Thanks for the help guys.
Old Jul 30, 2005 | 01:31 AM
sleepingeg6's Avatar
Default Re: 92 hatch w/ b18b. I've got questions (steelies)
you will need to re-place the tranny mount that is welded to the frame and use a 5-speed one from a civic and i think the rear y bracket im not to sure
Old Jul 30, 2005 | 02:47 AM
steelies's Avatar
Default Re: 92 hatch w/ b18b. I've got questions (sleepingeg6)
Alright.
Anyone w/ info on teh harness and ECU I'll need. I've got a 94 teg, but plan on keeping most of it intact, as it will now turn into my project car.
Looking for what I do about the d15 harness (i.e. wiring for the p75 5speed ecu, etc)
again, thanks for the help guys
Old Jul 30, 2005 | 06:27 AM
Jwbetley's Avatar
too much work and money.
Old Jul 30, 2005 | 06:51 AM
Mr. Wonderful's Avatar
youll definately need a integra ls ecu just make sure you get a 5 speed ecu that is the same obd code as the engine
Old Jul 30, 2005 | 07:18 AM
Agent_STFU's Avatar
Banned
Default Re: 92 hatch w/ b18b. I've got questions (Jwbetley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jwbetley &raquo;</TD></TR><TR><TD CLASS="quote">too much work and money. </TD></TR></TABLE>
Yeah, I don't think so.
You'll just need to use an LS ECU, If the motor is obd1 you'll need the obd1 ECU.
Old Jul 30, 2005 | 07:39 AM
you wont regret this swap btw. i love mine
Old Jul 30, 2005 | 09:49 AM
Agent_STFU's Avatar
Banned
Default Re: (...DjEk...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ...DjEk... &raquo;</TD></TR><TR><TD CLASS="quote">you wont regret this swap btw. i love mine</TD></TR></TABLE>
x2
Old Jul 30, 2005 | 10:12 AM
philosofy1's Avatar
Default Re: 92 hatch w/ b18b. I've got questions (...DjEk...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ...DjEk... &raquo;</TD></TR><TR><TD CLASS="quote">youll definately need a integra ls ecu just make sure you get a 5 speed ecu that is the same obd code as the engine</TD></TR></TABLE>
also, you only have to replace the upper tranny mount (hasport & jdmshit, both carry a auto - manual mount.), dont cut or weld, it looks sloppy. all the other mounts are fine. also make sure you add the clutch lines, pedal, resevoir, etc.
Old Jul 30, 2005 | 12:44 PM
Default Re: 92 hatch w/ b18b. I've got questions (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
also, you only have to replace the upper tranny mount (hasport & jdmshit, both carry a auto - manual mount.), dont cut or weld, it looks sloppy. all the other mounts are fine. also make sure you add the clutch lines, pedal, resevoir, etc.</TD></TR></TABLE>
Old Jul 30, 2005 | 12:56 PM
Fulthrotle's Avatar
Default Re: (Diseased Dreams)
x3
Old Jul 31, 2005 | 07:54 AM
Jwbetley's Avatar
Default Re: (Fulthrotle)
Theres more to it than that. A rear mount, a clutch kit, a flywheel,ecu, a shift fork, the whole shift linkage and shifter assembly, the slave cylinder, the hydrolic lines, the pedals from a manual civic, possibly the gauge cluster, the starter is different. I thnk you'll run into axle/ halfshaft problems. You would also need a few interior peices from a civic or integra. My advice, buy a donor car.
Old Jul 31, 2005 | 08:07 AM
90civichb's Avatar
Parts Necessary for a Civic Auto to Manual Transmission Conversion:
-Manual Transmission
-Clutch/Pressure Plate/Throw Out Bearing (your average clutch kit will do the trick)
-Flywheel w/bolts
-B-Series Shift Linkage
-Shifter (civic, integra, or del sol stock shifter will work fine)
-Shift **** (see comment from above)
-Clutch Fluid Resevoir
-Clutch Master Cylinder (Civic, Integra, or Del Sol)
-Clutch Slave Cylinder (Civic Integra, or Cel Sol
-Clutch Hard Lines (Civic, Del Sol, or Intgra should all work, or custom bent or braided steel lines..)
-Clutch/Brake Pedal Assembly (gas pedal doesn't need to be changed)
-Auto-Manual Conversion Mount (jdmshit.com has it for $110 shipped)
-Manual p75 ECU
-Manual Throttle Cable (I am not sure if this is necessary.. anyone?)
-Lower Manual Transmission Mount (OEM)
Wiring Directions Found Here:
http://brokenlimits.com/howto/...l.htm
With all of this, you can do your auto-manual swap easily. All you will have to do then is cut the center section of your car to let the shifter come through and move properly (see link above for visuals).
Old Jul 31, 2005 | 10:57 AM
Agent_STFU's Avatar
Banned
Default Re: 92 hatch w/ b18b. I've got questions (90civichb)
Well that was a helpful motherfuckin' post, if I do say so myself
Old Jul 31, 2005 | 01:05 PM
90civichb's Avatar
Default Re: 92 hatch w/ b18b. I've got questions (Diseased Dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diseased Dreams &raquo;</TD></TR><TR><TD CLASS="quote">Well that was a helpful motherfuckin' post, if I do say so myself </TD></TR></TABLE>
Im a helpful ************, what can I say?
Old Jul 31, 2005 | 01:27 PM
jessemarCc's Avatar
x4
Old Jul 31, 2005 | 05:45 PM
Default Re: (bluracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichb &raquo;</TD></TR><TR><TD CLASS="quote">Parts Necessary for a Civic Auto to Manual Transmission Conversion:
-Flywheel w/bolts
-Manual p75 ECU
sounds like somebodys done this b4. i wish everybody answered q's like that.
Old Jul 31, 2005 | 07:18 PM
BROKE.eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingeg6 &raquo;</TD></TR><TR><TD CLASS="quote">you will need to re-place the tranny mount that is welded to the frame and use a 5-speed one from a civic and i think the rear y bracket im not to sure</TD></TR></TABLE>
uhhhh no, the mounts are the same. you don have to cust or re-weld anything.
Old Jul 31, 2005 | 07:44 PM
steelies's Avatar
Default Re: 92 hatch w/ b18b. I've got questions (BROKE.eg)
Thanks for all the info guys. Going to be hard to go wrong w/ the info I've got now.
Old Jul 31, 2005 | 11:59 PM
90civichb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROKE.eg &raquo;</TD></TR><TR><TD CLASS="quote">
uhhhh no, the mounts are the same. you don have to cust or re-weld anything.</TD></TR></TABLE>
You sir, are wrong. If it is a 92-95 civic it will need either a conversion mount or a custom welded manual tranny chassis side mount. If it were a 96+ then you wouldn't have that issue.. please research before you reply.. Thanks
Old Aug 1, 2005 | 12:35 AM
JDMlyfestyle's Avatar
92-95 EG & Del Sol with a 94-2000 Integra LS B18 Engine.
Transmission: These Engines come with Hydraulic clutch transmissions including Japanese or American market Y21, Y80, S80, AND S4C. Japanese or American market S1, J1, A1, Y1 or YS1 cable clutch transmission with Hasport cable conversion kit part # M92-CC can be used.
Mounts: A combination of stock and integra mounts can be used if a hydraulic B- series tranny is used. on some 96 and up engines you may need to change the bracket under the timing belt and on the rear of the engine for ones of the appropriate year.
ECU: p75 from a 94-95 Integra
Electrical Differences: CX and VX need to convert to 4 wire o2 sensor. All models modify stock harness to fit.
Axles: 90-93 integra axles, 94-up integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP
Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol
Upper Radiator Hose: 94-Up Integra LS
Lower Radiator Hose: 94 Del Sol Vtec
Throttle Cable: 94 Integra LS
Clutch Hydraulics: Stock
Air Conditioning: 94-95 Del Sol Vtec A/C bracket
Special instructions: Using OBD II Ecu requires involved wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an Adapter harness will cut down on alot of potential problems
Special Considerations: Nice motor, Smog Legal, and excellent base for turbo car. Smog Legal in CA
daysofreign
10
May 4, 2007 10:20 PM
'92 HatchGuy
Feb 20, 2007 03:18 PM
EDVxRICHARD
11
Dec 11, 2004 07:24 PM
stripes777
Mar 7, 2004 06:05 PM
Evil EG
Jul 5, 2003 03:32 PM
