16x7 offset +32 with 205/45/16 on an EG hatch?
I'm planning to make a five lug conversion and I was planning on running a set of rims that are 16x7 offset +32 with 205/45/16, will they rub? what if I go with a set that is 16x7 offset +60, will it rub on the inside? If anyone gots advice or pic, it would be greatly appreciated.
That is a pretty low offset for the vehicle. I believe you would be ok but it will stick out towards the fender quite a bit. It isn't a guaranteed fit.
i had 38 off set before. it was kinda tight i had no wheel gap just flush and under full lock it would rub a tad. thats with a 16x7 with 205s
i rolled the fenders just a tad and it solved that. i was still able to fit my pinky in between so thats about 5mm. gives you an idea. this was with the camber set almost to 0
mamaboy
May 6, 2003 03:23 PM
