Questions about MSD Window Switch?
Old Feb 19, 2002 | 02:53 PM
LshatchTurbo's Avatar
New User
Default Questions about MSD Window Switch?
Anyone have a links, info or any general information on how to install a MSD window switch to a NOS system. Thanks
Old Feb 20, 2002 | 03:53 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Questions about MSD Window Switch? (Zynentech)
no need for the window switch. Use a rpm pill in the MSD 6AL that is 200-300 rpm below the ECU fuel cut.
Example,
D16Z6 with a Locash rechipped ECU.
Stock limiter = 7200 rpm
New Limiter = 8500 rpm
MSD pill = 7800 rpm
Old Feb 23, 2002 | 09:42 AM
Zeus's Avatar
...I used the window switch in line on a Zex box ground... tapped the blue tach test wire on the harness up by the brake master cylinder(ITR)... used 5800 and 8100 rpm pills and it ran great...
Old Feb 23, 2002 | 10:13 AM
USteppin's Avatar
Default Re: Questions about MSD Window Switch? (Zeus)
http://www.midnightautowerks.com/Ins...E36/MSDM3.html
BoredNStroked
Mar 12, 2006 09:36 PM
JHEIII850Turbo
May 20, 2005 01:30 PM
ubnpast
May 17, 2004 06:05 PM
LshatchTurbo
Feb 19, 2002 08:58 PM
