KNOCK SENSOR Blues....
Old Jul 29, 2005 | 06:30 PM
WOODman's Avatar
Default KNOCK SENSOR Blues....
(I got a 95 hatch Si with a b16a) both the motor and wiring harness require a knock sensor...the bad news its i cant find the plug on the harness... what issues can arise if i do not plug it in at all (would this alone be enough to make the check engine light come on?) **does anyone know a link for GOOD wiring and/or vacuume line diagrams*** thnks
Old Jul 29, 2005 | 07:52 PM
eda6's Avatar
Default Re: KNOCK SENSOR Blues.... (WOODman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WOODman &raquo;</TD></TR><TR><TD CLASS="quote">what issues can arise if i do not plug it in at all (would this alone be enough to make the check engine light come on?)</TD></TR></TABLE>
no vtec, check engine light, ecu will be in limp mode
Go to the junkyard and find the plug, get some ecu pins. After you've soldered and installed heat shrink tubing add the wire to the ecu plug (D3).
http://tech2.hybridgarage.com/..._obd1
btw wrong forum
quicksilverej6
Mar 22, 2006 05:48 PM
WOODman
Oct 7, 2005 07:09 PM
WOODman
Jul 30, 2005 02:31 PM
IHateJDM
Apr 14, 2005 07:06 AM
EGTHU6
Jul 28, 2004 01:50 AM
