93 Teg parting out and other misc. parts B series,rear disk, lots of parts CHEAP!!
Old Jul 29, 2005 | 05:48 PM
Zerob16eg's Avatar
Default 93 Teg parting out and other misc. parts B series,rear disk, lots of parts CHEAP!!
Ok guys my friend and i bought this GREEN 93 integra. It wa hit in the front so all frond end pices are not good. Please feel free to Email me at egreen00gsr@yahoo.com if you need a part that is not listed. All exterior parts are the DARK GREEN. Interiot pices are BLACK unless otherwise noted, I am pay pal verified and have done business on honda-tech, ebay, and have sold parts to other users here on G2IC. I have pictures of all parts that i have lised. Prices do not include shipping unless otherwise noted.
Parts that are already sold: Complete drive train, All 4 seats, and the bare dash, suspension, rear hatch, exhaust system, clutch cable, throttle cable.
Mileage on the odometer read 141,xxx.
Exterior:
-93 rear bumper: the plastic on the passenger corner has rash and needs plastic filler but is still useable 40obo
-93 rear tails: these are in good shape i would say 7.5 out of 10. there are a couple of small scuffs on the driver rear one but they can be buffed out with some rubbing compound. These come with the gaskets but one taillight does not have the harness. 65obo shipped
-Driver/Passenger doors: both are power doors Im not sure if i want to sell these as complete doors or part them. One door has no major dents and the other has some big dents (can be pulled). make offer
-I have the metal trim pice that is located under the taillights (the trunk lock sits into this pice) it has no dents, just needs some cleaning and a good home. 40obo
-Sunroof motor (no glass) 40obo
Interior:
-Black integra door pannels (power) 40obo for both
-Interior carpet, looks like it is a mix between blue and grey. Needs cleaned but is still useable 40obo
-E break unit with black trim pices and the black e break plastic pice that holds it. Both are in good condition. 30obo for both pices
-ecu cover plate 10obo
-93 integra gague cluster (non abs, has cruise, 5 speed) mileage reads 141,xxx. 50obo
-93 integra pedal assembly (5 speed) with cruise control box. Essential for the auto to manuel convertions. 40obo
Engine:
-93 teg distributor OBD 1 with cap, rotors, and wires 90obo
-COMPLETE interior harness OBD 1 ( includes dash harness, door harness,and all wiring and fuse block) Some of the wires towards the front of the car are a bit mangled but the wires off of your teg will wotk fine. 100obo
-93 integra exhaust manifold. Pipes are in good condition, no cracks 40obo
-93 teg pr4 OBD 1 ecu (5 speed) 75obo
Misc:
-Complete suspension off of a da integra. This is perfect for ANYONE with the 88-91 civic/crx that wants a better break set up. this is complete suspension minus the shocks. comes with master cylinder, porportioning valve, complete front/rear disks w/break lines and ebreak cables and calipers/rotors, front/rear sway bars, and all mounting hardware. i will part this out for the right price. 250obo for all of it
-Clutchmasters Stage 3 Pressure plate and disk for 90-91 tranny (includes pilot bearing) 100obo
-ACT 6 PUC and pressure plate LESS THAN 2K miles (includes throwout bearing and brand new pilot bearing) 90-91 tranny 150obo
-Integra half shaft (2) 50obo each
-i have like 3 stock clutches for the 90-91 trannys, email me for prices.
-Camber Kit for eg6/dc2 50obo
-pr3 socketed for hondata make offer
-panasonic cd deck has 3 sub options, cd changer option, detachable face, and remote. 80firm
-Blue AEM adjustable cam gears 150obo
-B18a1 bare block (i'll include oil pump,pistons,oil pick up/windage tray and whatever else i have) 75obo
-obd 0 pr4 ecu 80obo
-B series flywheel cover 25firm
-H series head bolts 30
-B series alternators/starters obd 0/1/2 40 each
-D series ex/si tranny, stuck in 3rd. 20obo
-H23 tranny (unknown condition, i was told that there was a slight scratch from 2nd-3rd at high rpm) 75obo
-Complete set of timing belt covers (3) for B series 50obo
-(2) Obd 1 Vtec harnesses both have been cut, both are still useable 50 each
-B Series Vtec Blue Accell plug wires 50
-Stock B16 valve cover off 00 SI (cut to show gears) looks good 50obo
That is all that i can think of right now. I also have some misc. interior plastics and trim/ weather stripping from the da. I have the front seat belts but i haven't had a chance to check and see if they still work.
EMAIL: Egreen00GSR@yahoo.com
AOL: GSR0078
Old Jul 30, 2005 | 02:35 PM
Zerob16eg's Avatar
bump
Old Aug 1, 2005 | 01:56 AM
Zerob16eg's Avatar
Default Re: (Zerob16eg)
to the top
Old Aug 2, 2005 | 04:03 PM
Zerob16eg's Avatar
bump it up
Old Aug 2, 2005 | 05:19 PM
shyxboy's Avatar
would buy something but your to far, bump
Old Aug 4, 2005 | 04:13 PM
Zerob16eg's Avatar
Default Re: (shyxboy)
i'll get you that shipping quote bro
missionaryrider
Jun 19, 2010 04:58 AM
