6-2-1 RB26 Mani.......
Old Jul 29, 2005 | 05:01 PM
LSiTurbo's Avatar
Default 6-2-1 RB26 Mani.......
ALMOST DONE!!!!!!!
Ray (statepolice! here on the boards) did all the fitup and most all deisgn. Ill be doing the welding next week when we get more gas. Just needs final welding, its all tacked together right now. Equal Length 321 Stainless 16g Tubular Manifold for RB26Z32 car. All material from http://www.burnsstainless.com including the collectors.
Each primary is 23" long.
This is the FIRST tubular manifold weve done. Needless to say we are very pleased with the outcome thus far.
Old Jul 29, 2005 | 05:56 PM
beepy's Avatar
Default Re: 6-2-1 RB26 Mani....... (LSiTurbo)
Wow. The downpipe is going to be a bitch.
Old Jul 29, 2005 | 06:19 PM
LSiTurbo's Avatar
Default Re: 6-2-1 RB26 Mani....... (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Wow. The downpipe is going to be a bitch.</TD></TR></TABLE>
Its hard to tell by the angle of those pics but we have room for a 4" downpipe no problem. This application will be using a 3.5" however.
Old Jul 29, 2005 | 07:07 PM
adictionbass's Avatar
that bitch is gonna hold some heat looks awesome tho
Old Jul 29, 2005 | 07:21 PM
DaveF's Avatar
Default Re: 6-2-1 RB26 Mani....... (adictionbass)
wild
wheres the WG gonna be located? or is it an internal gate?
Old Jul 29, 2005 | 07:31 PM
LSiTurbo's Avatar
Default Re: 6-2-1 RB26 Mani....... (Dturbocivic)
We know heat in the engine bay will be an issue with this car. It will have a large Cowel/Vented hood to clear the Engine and turbo so hopefully that will help.
The Wastegate will be locatedright by the #3 runner with a 2-1 collector coming off the 2 Burns collectors.
Thanks for the compliments guys!!!!
Old Jul 30, 2005 | 09:22 AM
david@didrace.com's Avatar
You used flux-core to tack up a stainless exhaust? I'm guessing that's just mild steel flux-core, in which case have fun with the rust. Way to go spending an easy $800 or so when you're going to end up with the same results as if you used all mild steel.
Old Jul 30, 2005 | 11:25 AM
alpha's Avatar
Been a while The exhaust manifold looks great. Cant wait to see it finished.
Old Jul 30, 2005 | 02:40 PM
LSiTurbo's Avatar
Default Re: 6-2-1 RB26 Mani....... (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">You used flux-core to tack up a stainless exhaust? I'm guessing that's just mild steel flux-core, in which case have fun with the rust. Way to go spending an easy $800 or so when you're going to end up with the same results as if you used all mild steel. </TD></TR></TABLE>
What?????
Its stainless wire in our Miller 135 MIG w/ gas.
0x64... it has been awhile buddy
Old Jul 30, 2005 | 08:39 PM
Accord94DX's Avatar
Relocate the power transistor on that POS engine. They overheat with the stock manis easy enough.
Old Jul 30, 2005 | 09:28 PM
91TSiGuy's Avatar
Default Re: 6-2-1 RB26 Mani....... (Accord94DX)
What gas mixture were you using to tach the runners? I'm also curious in general how people are measuring their runners to know that they are equal length. (Follow the inside or outside of the bends?)
Anyways, looks like the manifold has some nice potential once it's all welded up. Let us know the spool characteristics of the turbo then if you could.
Old Jul 31, 2005 | 07:35 AM
mrDFWmechanic's Avatar
wow that looks awsome i wonder how long that took to make
Old Jul 31, 2005 | 10:40 AM
Ekasey's Avatar
Default Re: 6-2-1 RB26 Mani....... (91TSiGuy)
You should be following the centerline of the bends or taking the inside and outside and finding the average.
Manifold looks great nice collectors
Old Jul 31, 2005 | 11:18 AM
RMF
Guest
Posts: n/a
Default Re: 6-2-1 RB26 Mani....... (Casey@Burns)
Casey your so smart!Yep that's the way you do it.Its nice to see full equal length turbo manifolds.One thing.WHY DID YOU TACK IT WITH A WIRE FEED?
You know how to weld around ALL the tubes right?Pick one of the tubes.And weld it up as much as you can.Weld it to the flange also.Now that ,that one won't break off .Cut the tacks at the flange on all the rest of them.And take them off.Then weld em up.Using the one that you welded on as an index for all the rest.And it will fall into place.Wire feeds are for making JIGS not headers.LOL
looks good so far.
Old Jul 31, 2005 | 12:59 PM
JCushing's Avatar
are you using a twin scroll turbo?
Old Aug 1, 2005 | 08:44 AM
LSiTurbo's Avatar
Default Re: 6-2-1 RB26 Mani....... (JCushing)
Yes, as it has been state3d follow the CL of the piping.
Casey, We were hoping youd see this..... after all the tech questions we bothered you with im glad you got to see where they went. Thanks again!!!!
Again guys.... we are not MIGing this entire manifold. We used a wire feed(w/ stainless wire) to tack all the pipes together as we had to make the manifold in the car for clearnace reasons. All those MIG tacks will be broken and grinded off after we scribe the location of the pipes and clean and prep for final TIG welding.
We used 100% argon on the MIG for tacks, however it isnt the most consitent machine.
The Turbo we are using is a GT35R .82AR
thanks again for the contructive critisim guys. This being our first tubular manifold, we know we still have alot to learn.
Old Aug 1, 2005 | 08:59 AM
snoochtodanooch's Avatar
looks good. Clean up that engine bay though . Those collectors do look very nice, burns stainless.
Old Aug 1, 2005 | 07:06 PM
91TSiGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSiTurbo &raquo;</TD></TR><TR><TD CLASS="quote">The Turbo we are using is a GT35R .82AR </TD></TR></TABLE>
That turbo and the .82a/r turbine is a hair laggy on the shop car at where I work, but it should be perfect for your RB26 motor. Going with the t04s ported shroud compressor housing too?
Old Aug 2, 2005 | 09:34 AM
LSiTurbo's Avatar
ITs a standard T04S compressor cover. No frills. We beleive with the 2.6 displacement and hopefully some help from this manifold this turbo will spool pretty quick on this car. The power goal is 500+whp on 93 octane pump gas..... well see how it goes.
Old Aug 2, 2005 | 09:55 AM
rhd's Avatar
rhd
i found a new appreciation for RB cars over the weekend....a friend of mine now has an R32 that's getting a single....and it's going to be EFFING NASTY....allready has nismo twin plate and nismo gears, with andrew's racing wheels too...
nice mani!
Old Aug 2, 2005 | 02:27 PM
LostCRX's Avatar
I've always wondered about this, do people use filler when tigging 16g metal?
Old Aug 2, 2005 | 02:29 PM
Ekasey's Avatar
Default Re: (LostCRX)
We do
Old Aug 2, 2005 | 03:01 PM
LSiTurbo's Avatar
Default Re: (Casey@Burns)
yep, after practicing with the PLENTY of straight material we have left over, ive decided I need to use filler for this. Fusing leaves too much undercut and/ or not enough penetration. With the filler i can move very slow on low amps and dip in the filler as i go. Atleast i personally feel more comfortable using filler.
Old Aug 2, 2005 | 09:50 PM
RMF
Guest
Posts: n/a
Default Re: (LSiTurbo)
Here is one that I did a couple weeks ago.Only fused it.If you get the purge right ,it will push the weld out ,not in.People that do sanitary tubing for food processing and Creameries don't use filler rod eather.They just fuse it.And it comes out perfect.
You can do it any way you want .I'm just sharing how I would do it.I'm sure it's going to come out fine however you do it anyway.
One thing to remember"You can tell a welder ,By the sound of his grinder" LOL
Modified by RMF at 11:53 PM 8/2/2005
Old Aug 2, 2005 | 10:36 PM
BoostedJeff's Avatar
very nice brian, looks very good is person. forgot to tell you, that damn dump didnt fit i suck at measuring
