B20 MOUNT ISSUE FOR "EG"...NEED HELP
Old Jul 29, 2005 | 04:46 PM
gsr_b20x2's Avatar
Default B20 MOUNT ISSUE FOR "EG"...NEED HELP
i have the timing belt bracket / motor mount and tranny mount bolted on, and the REAR LOWER TRANNY MOUNT will not line up correctly leaving about a 1 inch gap from the mount located by the fire wall....all my current mounts are from a 96' Gsr that threw a rod and was then replaced with the B20 block/gsr head and now there is this motor mount issue....does anyone know of the proper mounts i should be useing for the swap (95' civic coup / B20b manuel)
Old Jul 29, 2005 | 06:35 PM
gsr_b20x2's Avatar
Default Re: B20 MOUNT ISSUE FOR "EG"...NEED HELP (gsr_b20x2)
bump....please guys....its super urgent....
Old Jul 29, 2005 | 08:41 PM
gold eg's Avatar
all 94-up tegs (5-speed) have the same rear "k-bracket" this is the correct bracket you have. is this swap auto or 5 speed? all of the mounts from the teg will bolt the swap into all egs given 5 speed for 5 speed..
Old Jul 29, 2005 | 08:50 PM
gsr_b20x2's Avatar
Default Re: B20 MOUNT ISSUE FOR "EG"...NEED HELP (gold eg)
the swap is a 5 speed, 1995 Honda Civic Coup....we are, with both side mounts on....still about `1 inch short of reaching the bottom rear mount...
Old Jul 29, 2005 | 08:53 PM
jetpilot's Avatar
try rocking the engine, it MUST line up if you are using the correct mounts which seems you are.
Try to get it to reach the rubber on the subrframe
Old Jul 29, 2005 | 09:01 PM
DohctorVtec's Avatar
Default Re: (jetpilot)
Or heres an idea what most people do in swaps bolt up the rear lower mount first then the side mounts
Old Jul 29, 2005 | 09:14 PM
gsr_b20x2's Avatar
Default Re: (DoctorVtec)
so what u guys are saying is that....all the mounts i am using are the right ones...hmm...this is verrrry strange, makes no sence at all....unless anyone else has more info...i guess i might have to try the REAR BOLT-UP technique first thing tomorrow... but eveyone that takes a lok at it is saying that we must have at least one of the brackets wrong...
Old Jul 29, 2005 | 09:33 PM
Rhythm's Avatar
I had a similar issue when i did my ls motor swap. It turned out that I had a 99-00 Si b16 mount and it won't work in an EG. Good luck!
Old Jul 29, 2005 | 10:06 PM
gsr_b20x2's Avatar
Default Re: (Rhythm)
nope...i got all Gsr mounts from a 96 Gsr because of the prior motor....
Old Jul 30, 2005 | 03:40 AM
non-VTEC's Avatar
it should line up unless the guy you got the "gsr" mounts from gave you a mount for some other vehical.......loosen most of the mounts a little and wiggle/rock the engine around a little it should line up as long as its the correct mount......
Old Jul 30, 2005 | 09:26 AM
gsr_b20x2's Avatar
Default Re: B20 MOUNT ISSUE FOR "EG"...NEED HELP (non-VTEC)
ok kewl...naw the Gsr mounts are correct...i just pulled my Gsr out like 2 months ago from my same 95 civic coup after i threw a rod...but this is starting to make sence now a little...we had the side mounts touqued down when we were trying to fit the rear mount on...this time i will losen all the mounts then get them all on PRIOR to bolt down...ill let you guys know what happened by the end of the day...thx again NoN-V - swift
potatointegra01
Jan 15, 2016 03:21 PM
Galaxy Si
May 9, 2007 10:06 AM
gsr_b20x2
Aug 2, 2005 06:48 AM
Blaze45
Mar 17, 2003 07:22 PM
Will Albers
Sep 30, 2002 08:03 AM
