Code 20 and battery light
Old Jul 29, 2005 | 03:32 PM
Pete_SI's Avatar
Default Code 20 and battery light
WE just installed a lsvtec and we are getting code 20 and a battery light. We had a D serie just before that and had nothing of that. what could be the problem...maybe a the alternator?
Old Jul 29, 2005 | 03:47 PM
Luserkid's Avatar
Default Re: Code 20 and battery light (Pete_SI)
20 Electrical load detector
Edit: yep its in the fuse box.
Oren's Avatar
I think code 20 is ELD, It's part of your fuse box.
Does the engine turn over?
Old Jul 29, 2005 | 03:54 PM
Pete_SI's Avatar
Default Re: Code 20 and battery light (Oren)
Yeah everything work fine. also the battery only make 9.5V and when we boost it its make 13V.
edit: the car starts but it doesn't run very good.
Old Jul 29, 2005 | 04:15 PM
Luserkid's Avatar
Old Jul 29, 2005 | 04:20 PM
Pete_SI's Avatar
Default Re: Code 20 and battery light (Luserkid)
Thanks a millions..I will try that.
Old Jul 30, 2005 | 04:49 PM
kenji's Avatar
25 Year Member
Also, check to make sure you did not ground out your O2 sensor 12v switched wire (yel/blk). This happened to a friend of mine.
-kenji
Old Jul 30, 2005 | 05:07 PM
Prod's Avatar
Default Re: Code 20 and battery light (kenji)
maybe a silly question but u did connect the white wire from the alt into the fuse box right ?
XSlor
Dec 11, 2017 01:46 PM
derrickjon
Oct 23, 2016 04:17 AM
D831SI
Acura TL, RL & ZDX
Nov 27, 2012 11:57 PM
bburtonsk8r2
Dec 14, 2006 05:58 PM
DarkElfTRP
Honda Civic (2001 - 2005)
Oct 5, 2006 11:25 PM
