To cut or not to cut, that is the question.
Old Jul 29, 2005 | 01:18 PM
KeyserSoze's Avatar
Default To cut or not to cut, that is the question.
I have a turbo manifold (made out of mild steel I assume), and it has a solid flange where it mates up with the head. My question is should I put some slats (cuts) in it to allow for thermal expansion? I know that some companies do this or make the holes progressively larger from inside out. If I made any cuts they would probably be made to seperate the individual exhaust ports. Anyone done this or think I should just leave it alone??
Old Jul 29, 2005 | 01:53 PM
ExploitedRacing-HR's Avatar
i cut all mine
Old Jul 29, 2005 | 04:01 PM
KeyserSoze's Avatar
Default Re: (ExploitedRacing)
Ok, do you cut it like I was saying? One cut in between each outlet port, so each outlet can grow how it wants or do you make cuts on the bolt holes (which I have also seen)?
Old Jul 29, 2005 | 04:37 PM
between each port.
Old Jul 29, 2005 | 04:40 PM
KeyserSoze's Avatar
Cool, thanks. Appreciated.
Old Jul 31, 2005 | 02:37 PM
The Phil's Avatar
Is that why flanges are never holes in a large solid piece of metal?
Exploited, could you take a picture of one of your cut flanges and mark where you made the cuts if its not obvious?
Thanks.
autosport7
Welding / Fabrication
Mar 22, 2007 10:03 PM
RCautoworks
Mar 12, 2007 03:56 PM
UnnaturalAspirations
Apr 17, 2005 08:40 PM
92HB_HB
Aug 23, 2003 08:38 AM
youngkow
Oct 15, 2002 06:28 PM
