short shock koni?
Does koni make a yellow with smaller shock body? I was planning on slamming with them but I don't want to have to worry about hitting my bumpstops. Or is my concern completely unwarrented?
you should not combine shortened koni yellows with ground control top hats. its too much. just do either/or.
yeah, top hats allow the bumpstop to travel a bit further up. i would only recommend using these also if you are using GC adjustable spring kits. i dont recommend them with regular springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbmprelude »</TD></TR><TR><TD CLASS="quote">how do these ground control upper mounts help with travel? Do they mount the bumpstops further away?</TD></TR></TABLE>
the top hats raise the shock mounting points by about 1in
so gorund control upper mounts and top hats are the same thing? Also when you purchase gcs, would you normally use your stock upper mounts with them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">i would only recommend using these also if you are using GC adjustable spring kits.</TD></TR></TABLE>
Why not any coilovers?
The reason I ask is because a friend of mine has ots konis and gcs on his ek hatch but he is slammed. The ride is very bouncey and he says it is becasue the shock travel has been reduced so much?
Iloveyourhonda92
Suspension & Brakes
10
Nov 2, 2010 10:45 PM
racekar711
Suspension & Brakes
Dec 2, 2005 08:30 PM
