5th Gen - SRS light.
Old Jul 29, 2005 | 10:15 AM
{PMS}fishy's Avatar
Default 5th Gen - SRS light.
Its been to the dealer twice, and they still can't fix it. The car doesn't thorw any codes, and they want to replace the entire SRS system, for about a $1000.
It came on one day, while driving, and then didn't come back on the car when it was restarted. A week or so later, and its back, and it won't go away now.
Any ideas?
Old Jul 29, 2005 | 10:21 AM
fe519's Avatar
Default Re: 5th Gen - SRS light. ({PMS}fishy)
i have the same problem but with a 6th gen. How long is the warranty to fix this problem at the dealer anyways?
Old Jul 29, 2005 | 01:31 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {PMS}fishy &raquo;</TD></TR><TR><TD CLASS="quote">Its been to the dealer twice, and they still can't fix it. The car doesn't thorw any codes,
If all the fuses are good, the srs control unit could be the problem.
Old Jul 29, 2005 | 04:16 PM
XxRONNxX's Avatar
New User
How much did they charge you to reset the light?
Old Jul 29, 2005 | 04:39 PM
YeuEmMaiMai's Avatar
Default Re: 5th Gen - SRS light. (XxRONNxX)
I would try removing power to the tcu unit and see if that solves the problem
Modified by YeuEmMaiMai at 9:08 PM 7/29/2005
Old Aug 6, 2005 | 05:35 AM
{PMS}fishy's Avatar
Nothing. It was there for another issue too.
Old Aug 6, 2005 | 03:54 PM
Diego Dangers.'s Avatar
if the light is on, it has to be throwing an SRS code. If you know someone that has access to a scanner, and by scanner, I mean a real scanner with Honda modules and waht not and throw it on. Go to the airbag section and it should throw you a code or two. It may be as simple as the seat belt having a short as to an airbag having a short.
HondaHemi
Nov 29, 2006 05:44 PM
DANgerous
16
Jun 13, 2006 01:27 PM
aZnPIGbOi
Feb 2, 2006 09:11 PM
