my new setup LS/VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone »</TD></TR><TR><TD CLASS="quote">what compression is that going to be?</TD></TR></TABLE>
if he's using ls rods... about 11.2:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 »</TD></TR><TR><TD CLASS="quote">With a p72 head, its more like 11.5:1</TD></TR></TABLE>
thank you!
thank you!
You should probably use the ITR pistons with LS crank and rods. The ITR rods will destroke your engine I think. And using the ITR pistons, the rod or piston will need to me modified to work. PR3's like the ones being used above will not require modification and will give you similar compression.
TurboHatchB16
Aug 10, 2008 02:58 PM
