Help: My 1999 Accord Player swalled by CD
oWhen I try to take the CD out, it reads CD Err. Can I get it out? Called Honda but they say that they do not touch the player and will need to send it back to manufacturer which shall cost a lot of dough to get the CD out..please help
Modified by dcmetro at 1:29 PM 7/29/2005
Pull the CD player, and take the top cover off, and get your cd out... Then, either get that deck serviced or put a new one in...
Thanks for your reply.
How does one pull out the CD Player? Are there any instructions/guides/pointers that you could point me to? The stock player seems to be well grounded in the console.
There should be a little tiny hole you can stick a paper clip inside of it and push it to push out the CD. You will have to unfolded the paper clip first. Most all CD players have this, especially on computers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcmetro »</TD></TR><TR><TD CLASS="quote">Thanks for your reply.
How does one pull out the CD Player? Are there any instructions/guides/pointers that you could point me to? The stock player seems to be well grounded in the console.</TD></TR></TABLE>You can also try a reboot, if it is a coded unit make sure you have the code before you try this, disconnect the neg. (-) batt lead, wait a min. reconnect, if the unit was just "latched up" as it reboots it will eject the disc, if it does not, try the eject button, if it still will not eject, do as B18C_EJ8 said, you can find removal here http://www.installdr.com
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine »</TD></TR><TR><TD CLASS="quote">There should be a little tiny hole you can stick a paper clip inside of it and push it to push out the CD. You will have to unfolded the paper clip first. Most all CD players have this, especially on computers.</TD></TR></TABLE> Unfortunately, very few if any oem HU have the "reboot switch", but undoing the batt. is the same as pushing the reboot switch, or you could pull both the fuses
94
94
Reboot did not work since I had to get the battery replaced last week and therefore "reboot" occured but even after that did not take out the CD for me. Still stuck inside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Radio should be held in by 4 screws (phillips or 10mm) that are revealed after popping off your radio trim panel with a panel-removal tool.. </TD></TR></TABLE>Oops, not so....http://www.installdr.com/InstallDocs...PDF/466037.pdf a little more to it.
94
94
Umm, yeah... He said he had a 99 Accord... You gave instructions up to 98...
But I gave wrong info, too.. There are 2 screws on the bottom of the dash bezel, and one behind the clock before the piece will come out....
http://www.installdr.com/Insta...3.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Umm, yeah... He said he had a 99 Accord... You gave instructions up to 98...
http://www.installdr.com/Insta...3.pdf</TD></TR></TABLE>Doohhh, you are correct, I don't know how the hell I got that so wrong, and it wasn't because I just make a mistake on the link, I thought it was a 94, O dummy me
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P95 »</TD></TR><TR><TD CLASS="quote">i was just really careful and pulled the cd out with pliers.
i had a really small pair so i wrapped teflon tape around it so the metal wouldnt touch the cd. worked fine for me.</TD></TR></TABLE>That will only work if disc is not fully loaded
94
94
another trick I've had success with is to use a junk CD (cd-r coaster, etc), stick it into the slot under the stuck CD, and use that to help "pull" the stuck disc out. There are a few headunits this doesn't work for. I think JVC may be one, because some head units have two little "tabs" that block you from sticking a 2nd CD in on accident.
Sarge! Carry On!
Oct 28, 2006 10:41 AM
Bone Stock
Nov 17, 2005 11:39 AM
