oil seal change with oil pump swap?
so replaced my main oil seal on my OBD2 motor when i did my timing belt/water pump a few months ago. now i have a built OBD1 block and i want to use the OBD2 oil pump so i can use my crank sensor. should i replace the oil seal or will it be fine? what other seals should be replaced?
Boostless97Lude
Jan 8, 2003 09:53 AM
