1/4 mile times?
What do you guys estimate my quarter mile time to be and horsepower/torque with this setup?
-G.E. Sleeved block to 84.5mm
-LS head
-Type R flywheel
-Clutchmasters stage 4 clutch
-ls tranny
-Endyne 9:1 compression rings/pistons
-Eagle rods
-type R oil pump/new water pump
-New bearings/gaskets/seals
This is going in a 94 integra LS. TIA!
-LS head
-Type R flywheel
-ls tranny
-Eagle rods
9:1 = ****. If you really want a fast LS using the LS head/block you are going to need to raise the compression more and get some more agressive cams. Compression really wakes up the LS.
Well, I didn't want to say I was turboing it becuase I just want to know what i will run with just the rebuilt. Its going to be awhile till I turbo it
I doubt I would be running 12's or high 11's on just the rebuilt, I dont expect to do that untill I turbo it
Im hoping to run high 14's with advanced timing and racing fuel, do you think thats possible?
97blackteg: You're right most of the stuff im adding are just stronger replacements, except for the fact that it is 84.5mm bore instead of 81.5mm bore and a lightened flywheel. Maybe Im just getting to excited
quikgs-r: thanks, Im getting the drag III kit with tial upgrade and ball bearing upgrade. I will probably run 9 psi for awhile, but Im worried about detonation. I was thinking I would get the J&S safeguard to help prevent it. Also in the future I will get hondata 4b and hopefully boost 15-20psi on the street. Thanks for your input, any other suggestions?
reaction time off the light has nothing to do with the overal ET. i think this car will run like mid 16s or worse but its all good as long as u get the turbo
it all depends on ur footwork and ur reaction time, i estimate mid 14s to 16's
